Hi All,
I have 4 cablem modem that i want to feed into 1 router (mikrotik), all modem are DCHP mode.
First two modems are fine, because they have different gateway, but when i feed the next modem, it’s got the same gateway as the second modem, last modem has the same gateway as the first.
I’m using routing mark for traffic balancing.
Many thanks for any advice.
PS: all i can think of is having another router on top of the mikrotik router so it gives a different gateway. But i’m sure there must be other ways.
