Like many people i decided to go with a RB5009 instead of a RB4011 to replace my RB750G r3(all providers offer gigabit internet so it was no longer up to the task) however being a v7 only piece of equipment, changes took place that make the ubiquitous PCC configuration found on the internet invalid but working to some extent.
v6 config is for that part :
/ip firewall mangle
add action=mark-connection chain=input in-interface=pppoe-out1 \
new-connection-mark=ether1_conn passthrough=yes
add action=mark-connection chain=input in-interface=pppoe-out2 \
new-connection-mark=ether2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=ether1_conn \
new-routing-mark=to_ether1 passthrough=yes
add action=mark-routing chain=output connection-mark=ether2_conn \
new-routing-mark=to_ether2 passthrough=yes
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=bridge1 new-connection-mark=ether1_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/0
in-interface=bridge1 new-connection-mark=ether2_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=ether1_conn \
in-interface=bridge1 new-routing-mark=to_ether1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ether2_conn \
in-interface=bridge1 new-routing-mark=to_ether2 passthrough=yes
It fails with the error message “input does not match any value of new-routing-mark” at :
/ip firewall mangle
I did due dilligence and read other topics about this on the forum, i’m aware i’m supposed to create a table in routing however this where my comprehension of the change stops.
Is there a charitable soul to translate this to the newer routerOsV7 equivalency?
Thanks in advance.
