HELP needed! - Wireguard Site 1 <--> Site 2 (both Mikrotik router)
Hello!
I would like to ask for help to correctly configure 2 mikrotik routers, as follow;
target:
  • wireguard tunnel to be able to communicate between each others LAN (Site1 ←→ Site2)
  • Site 2 router should exit to internet via Site 1 Public IP (the same public IP from Site1 router)
  • Site 2 router to have separate (isolate Guest WiFi) - access only to Internet (WAN)
  • Site 1 router - Aditional Wireguard server to be able to connect peers (like iPhone, tablet, etc…) and be able to access Site 1 subdomain LAN devices and peers should have exit point to internet of Site1 router public IP
I started setup by following tutorials but it just don’t work (after multiple reset config I quit). So I stopped before adding any aditional firewall rule just not to confuse everybody (myself included) :slight_smile:
Anybody willing to help by tell me what exactly should i add / change (c/p to terminal would be much appreciated :slight_smile:
E D I T:
Let me answer myself; hap ax s has BTH option , easy to setup. It’s kind like workaround but it works for me.
