help needed with IP's
Hi every one, I have mikrotik server ver 4.11 and it was working good but we change our I.S.P
Our new I.S.P give us his new ip’s which are :
ip: 87.101.225.132/29
gw: 87.101.225.129
dns: 87.101.238.5,87.101.238.6
I try this ip’s direct on my pc and the INTERNET work perfect but when I put them on mikrotik it stop working
By the way our new I.S.P give us INTERNET from an antenna on the roof direct to our network.
I attach two setting files one with old setting that was working well and the new is with new setting but not working
please advice
setting.rar (3.78 KB)
If you can post “/ip address” and “/ip route”, maybe I can help. I don’t have unrar package installed here.
Also post the interface to which your ISP device will be connected.
These are my old and new IP'S
----------OLD ISP Was Working good---------
add address=192.168.0.200/24 broadcast=192.168.0.255 comment="" disabled=no
interface=Internal network=192.168.0.0
add address=192.168.1.10/24 broadcast=192.168.1.255 comment="" disabled=no
interface=External network=192.168.1.0
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 primary-dns=84.235.4.55 secondary-dns=84.235.6.55\
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
192.168.1.1 scope=30 target-scope=10
----------NEW ISP Not working---------
add address=87.101.225.132/29 broadcast=87.101.225.135 comment="" disabled=no
interface=External network=87.101.225.128
max-udp-packet-size=512 servers=87.101.238.5,87.101.238.6
87.101.225.129 scope=30 target-scope=10
Please Help
Did you remove the old “/ip address” and “/ip route” entries?
Maybe something in “/ip firewall nat” or “/ip firewall filter” that could cause the fail?
Of course I change the old addresses to new one.
And you can see that in my first attachment
I can’t open the attachment. I do not have unrar package installed here. I have unzip! :smiley:
attached again with zip file
Setting.zip (4.43 KB)
I do not see “/ip route” on the new setup. Can you post just that? “/ip route print” would be best.
this is the ip route on the new isp
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
The only other thing I see is the second redirect. Might want to try disabling that rule. It will redirect any dst-address port 80 to port 8080. Is that what you want? Like proxy?
add action=redirect chain=dstnat comment=“” disabled=no dst-port=80
in-interface=External protocol=tcp to-ports=8080
add action=redirect chain=dstnat comment=“” disabled=no dst-port=80 protocol=
tcp to-ports=8080
yes I want that as it work good for me before
Then it is your proxy server that gets the port 8080 requests? Have you tried disabling that rule as a test? You don’t need to remove it. If it doesn’t correct the problem, enable it again.
ADD: In the Before setup, you had “/ip proxy” enabled. The New doesn’t.
