Hey guys,
I’ve just swapped out a wireless card in an RB532 AP, from a CM9 (Atheros, 65mW) to an NL-2511MP (Prism 1, 200mW) card.
Signals have improved, pings go thru, but thats about it. Going to web sites on the wireless hardly works, and I can’t fully login to another RB532 I’m using at home on the wireless.
Here’s the layout:
RB532 AP (NL-2511MP) ---- CPE (-67 signal) ---- RB532 router (home)
Pings from the RB532 AP are 4 - 9ms, very stable.
Telnet/Winbox to my RB532 home router connect and present me with the user/password login, but then after entering the password (telnet) it hangs. Reconnect to reattempt it, and it does the same thing again.
The RB532 AP’s resources and log look fine – it loaded the prism firmware ok, and everyone’s connecting to it, but the wireless from the AP to the customers seems unstable, not able to load web pages across it.
[admin@Windrum MT] interface wireless> print
0 R name=“wlan1” mtu=1500 mac-address=00:02:6F:3A:8C:F2 arp=reply-only
disable-running-check=no interface-type=Prism prism-cardtype=200mW
radio-name=“Windrum Hills” mode=ap-bridge ssid=“sherwood” area=“”
frequency-mode=regulatory-domain country=united states antenna-gain=15
frequency=2417 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-b=1Mbps
max-station-count=2007 tx-power-mode=default
periodic-calibration=default periodic-calibration-interval=60
dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=pre-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms compression=no allow-sharedkey=no
I’ve updated the RB532 AP’s firmware from 1.5 → 1.13, and RouterOS from 2.9.18 → 2.9.27. The BIOS on it used to be configured for power save CPU mode, but now I have it configured for ‘regular’.
Any ideas? ![]()
