I have setup a Radius (116.226.26.6) and Access Gateway (192.168.16.6) in the network.
If i use a Laptop to search for the WiFi SSID, and once i’m connected, i open a browser to browse to let say http://www.google.com, it will redirect me to the Login Page. The Login Page shown on the address bar is “116.226.26.6:8002/portal/login”
The CPE (RB411) that I’ve setup does not work with that.
I check in the Winbox and it is connected to my AP but i was not able to get the login page although i’ve open the browser and browse. It just dun want to direct me to the login page. It will say, “Webpage found.. waiting for google.com” or something like that and it will end up “Page not found”.
I’ve set WLAN DHCP-Client and get the IP of 192.168.16.11, and i’ve the ether1 IP POOL and given 192.168.8.100~150. Firewall NAT is set to chain=srcnat, action=masquerade.
Do you guys face the same problem too? How do you solve it?
Sorry of all this trouble. I’m a newbie.
Do you have Hotspot running on the AP?
Are you able to post a copy of your config (open terminal → type: export → paste config)
Is the CPE routing or Bridging to your computer/laptop?
I have found when connection 2 Mikrotiks wirelessly, if either side is bridging to make sure you use WDS, otherwise it will connect, and traffic will pass (DHCP Lease) but other traffic won’t pass (ARP entries). It makes sense why they do this, just a Mikrotik Trick.
With that being said, if anyone else is reading this, I have successfully bridge WLAN interface to an Ethernet Interface with no issue. It all depends on the application.
In the CPE confirm that the dhcp client (wlan1) is set to use peer dns and default route.
Give ip to ether1 and create your ip pool or dhcp server on that interface.
If you have another device doing srcnat upstream, the masquerading is not necessary in the CPE.
The part i’m not clear about is your upstream setup.
What device are you using for radius?
When you say access gateway (192.168.16.6), do you mean access point?
Please clarify the upstream setup (radius, access gateway etc)
If you want to add wlan1 and ether1 to a bridge, you will have to put wlan1 in station-pseudobridge mode, not station mode. You then make bridge1 a dhcp client.
An alternative is to use MPLS http://wiki.mikrotik.com/wiki/MPLS_Lab_Setup
edit: And WDS is yet another alternative as described below.
There are a few different ways of doing it. How I would recommend to do this:
AP Setup
Bridge → Bridge
Create a bridge interface
If you want your wireless traffic to go to your ethernet traffic on that tower add ether port to bridge (under Bridge → Ports)
All your wireless stations requesting WDS will go into this interface, so your Hotspot, IP address, DHCP-Server, etc. would need to be on this bridge interface.
