Hello everyone, I saw this on Mikrotik Wiki on how to help prevent people from using Port Scanners to find out what ports we use on our routers.
My Question is if I use this rule (Below), and use the Forward Chain command, will this automatically drop those IPs that are trying to scan on our network ?
Drop port scanners
To protect the Router from port scanners, we can record the IPs of hackers who try to scan your box. Using this address list we can drop connection from those IP
in /ip firewall filter
add chain=input protocol=tcp psd=21,3s,3,1 action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment="Port scanners to list " disabled=no
Various combinations of TCP flags can also indicate port scanner activity.
add chain=input protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“NMAP FIN Stealth scan”
add chain=input protocol=tcp tcp-flags=fin,syn action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“SYN/FIN scan”
add chain=input protocol=tcp tcp-flags=syn,rst action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“SYN/RST scan”
add chain=input protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“FIN/PSH/URG scan”
add chain=input protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“ALL/ALL scan”
add chain=input protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg action=add-src-to-address-list address-list=“port scanners” address-list-timeout=2w comment=“NMAP NULL scan”
Then you can drop those IPs:
add chain=input src-address-list=“port scanners” action=drop comment=“dropping port scanners” disabled=no
Similarly, you can drop these port scanners in the forward chain, but using the above rules with “chain=forward”.
