Help on wireless issue, Netgear WAB102 and Mikrotik w/CM9 not talking to each other…
I am trying to connect a mikrotik station with a CM9 to a Netgear WAB102 access point, the WAB102 has two radios inside of it, one 5G-802.11a and one 2.4G-802.11b.
First I setted up the mikrotik w/CM9 to be a 5Ghz station, no encryption, no auth, open SSID, but they dont associate, on the status screen of the wab102 it shows the CM9 authenticated but no asociated
ID MAC Address Channel Type Status
1 00:0B:6B:35:FD:98 161 / 5.805GHz A authenticated
and on the mikrotik log :
01:22:57 wireless,debug CM9: STA starts scanning
01:22:59 wireless,debug CM9: STA scan over, results:
01:22:59 wireless,debug 00:09:5B:40:6A:B8: on 5805 SSID Wireless caps 0x1 rates 0xff00 basic 0x1500 MT: no
01:22:59 wireless,debug CM9: must select network
01:22:59 wireless,debug CM9: 00:09:5B:40:6A:B8 failed to join recently
01:22:59 wireless,debug CM9: no network that satisfies connect-list, by
default choose with strongest signal
01:22:59 wireless,debug CM9: failed to select network
01:22:59 wireless,debug CM9: delaying scanning
01:23:00 wireless,debug CM9: STA starts scanning
01:23:02 wireless,debug CM9: STA scan over, results:
01:23:02 wireless,debug 00:09:5B:40:6A:B8: on 5805 SSID Wireless caps 0x1 rates 0xff00 basic 0x1500 MT: no
01:23:02 wireless,debug CM9: must select network
01:23:02 wireless,debug CM9: no network that satisfies connect-list, by
01:23:02 wireless,debug CM9: selected 00:09:5B:40:6A:B8, SSID Wireless on 5805
01:23:02 wireless,info 00:09:5B:40:6A:B8@CM9: failed to connect, assoc
Then I switched the CM9 to 2.4Ghz/b
On the wab102 status screen:
1 00:0B:6B:35:FD:98 11 / 2.462GHz B associated
Its says asociated but no data goes thru…
and on the mikrotik log:
01:26:12 wireless,debug 00:09:5B:40:6A:B9: on 2462 SSID Wireless caps 0x21 rates 0x0 basic 0x0 MT: no
01:26:12 wireless,debug CM9: must select network
01:26:12 wireless,debug CM9: 00:09:5B:40:6A:B9 failed to join recently
01:26:12 wireless,debug CM9: no network that satisfies connect-list, by
01:26:12 wireless,debug CM9: failed to select network
01:26:12 wireless,debug CM9: delaying scanning
01:26:13 wireless,debug CM9: STA starts scanning
01:26:15 wireless,debug CM9: STA scan over, results:
01:26:15 wireless,debug 00:09:5B:40:6A:B9: on 2462 SSID Wireless caps 0x21
01:26:15 wireless,debug CM9: must select network
01:26:15 wireless,debug CM9: 00:09:5B:40:6A:B9 failed to join recently
01:26:15 wireless,debug CM9: no network that satisfies connect-list, by
01:26:15 wireless,debug CM9: failed to select network
can anybody point me in the right direction on how to make these two talk to each other?
Best
Jorge Boardman
