help! one hotsport with two radius and username with domain in hotsport
Hi everyone~
I have one ccr1036 and setup one hotspot, I have two different kind of users, so I want to use two radius for different users.
It is possable to use domain to do it ? I find setting in "/ip hot profile " that I can define a default doman.
Is that means users can input a username with domian so that the hotspot can decide which radius should send to ? Huawei can do it,by the way..
If this is true, is anyone know the format of the user name with domain ,I have tried “doman\usename” “username\domain” “username@domain” and “username.doman”
Default domain to use for RADIUS requests. Allows to use separate RADIUS server per /ip hotspot profile. If used, same domain name should be specified under /radius domain value.
yes you can specify the domain name and specify the exact in /radius server definition
also you can do it with freeradius and multiple sites.
