The counters in mangle are running, but not showing any traffic in simple queue.
There are “P2P Conn” in firewall connections list.
But though, ‘without’ using mangle rule, the P2P (NOT “P2P Conn”) were also shown in firewall connections P2P as well
(bit-torrent, e-donkey etc) … I’m Confused!
Well postrouting is going after prerouting, use prerouting chain.
However if you are not familiar with chaings and mangle, one queue simple entry is enough,
‘queue simple add target-address=x.x.x.x/xx p2p=all-p2p’ and required limits.
NA P2P queues not working with the new versions for Gneutella & Bit-Torrent,
The UTorrent new client works even if you add a filter in the firewall and drop “all p2p”
I have tried lotsa tricks but does not work, you do block the dumb users who use old clients.
The best way would be to monitor packets on the network and accordingly mark all relevant packets , rest mark together n limit them like shown in Transparent Bandwidth Shaper in wiki.
i searched over the forum nobody had proper solution to limit P2p torrent limiting (shaping) methods.
Nobody had sucess , mikrotik people have to answer for it, is it is possible or not
If yes try to give any script or reference url, i will help all of the mk users.
thank you
