Help PCC Dual WAN Load Balancing
Dear all,
Hope you will be fine.
it is stated that I have 2 WANs from the same ISP each WAN is 70Mbps Now I want to PCC Load Balancing on 2 WANs.
Is the mentioned Script enough for PCC Load Balancing?
/ip firewall mangle
add action=accept chain=prerouting disabled=no in-interface=pppoe-out1
add action=accept chain=prerouting disabled=no in-interface=pppoe-out2
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local new-connection-mark=wan1_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0 src-address=172.16.0.0/24
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local new-connection-mark=wan2_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:2/1 src-address=172.16.0.0/24
add action=mark-routing chain=prerouting connection-mark=wan1_conn disabled=no new-routing-mark=to_wan1 passthrough=yes src-address=172.16.0.0/16
add action=mark-routing chain=prerouting connection-mark=wan2_conn disabled=no new-routing-mark=to_wan2 passthrough=yes src-address=172.16.0.0/16
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1 src-address=172.16.0.0/24
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out2 src-address=172.16.0.0/24
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_wan2 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=10
https://www.youtube.com/watch?v=nlb7XAv57tw&t=568s
Thanks for sharing,
But I have a problem. As mentioned in the video. when I deployed the same configuration as in the video when I checked in connection tracking there is no connection which is marked as isp1_conn and isp2_conn.
when I again restore to my previous PCC load balance configuration I checked in connection tracking is working well but few established connection has no mark connection to tou bound all connection with wan.
Is my configuration enough or not or i need to add few rule in my existing configuration.
ip firewall mangle
Suggest you provide a network diagram and your full config
/export file=anynameyouwish (minus router serial # and any public WANIP info)
First thing I noticed off the bat is that I had issues with something similar to:
ip firewall mangle
This just accepts the incoming packet, with no marks or anything. The problem with that is, if the packet comes in over pppoe-out1, the router may try to send it back out pppoe-out2, thus breaking…anything really.
What you should do is mark the connection when it comes into the WAN interfaces. This is an example of how I am running dual wan
## Mark connections coming in from each WAN so it goes back out over same interface
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-out1 new-connection-mark=ISP1_conn passthrough=yes
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether4-WAN2 new-connection-mark=ISP2_conn passthrough=yes
## Mark new connections that do no have a connection-mark to use one of the two WANs (based on per connection classifier)
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge new-connection-mark=ISP1_conn passthrough=yes per-connection-classifier=src-address:2/0
/ip firewall mangle add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge new-connection-mark=ISP2_conn passthrough=yes per-connection-classifier=src-address:2/1
This of course is just a small slice of the configuration needed for dual WAN to work. I have been working on trying to perfect a setup for the past week, and think I am nailing it down.
