[HELP PLEASE] Mikrotik v3 x86 - Webproxy issue using 2wans
As i wrote on my last post, there is an issue using web-proxy upgraded from v2.9.50 to v3.x (including the last v3.3).
As I read on the mikrotik manual at web-proxy reference guide:
src-address (IP address; default: 0.0.0.0) - the web-proxy will use this address connecting to the parent proxy or web site.
0.0.0.0 - appropriate src-address will be automatically taken from the routing table
My mt box has 2 different wans IP, and i´m using policy routing to redirect web traffic to gw 179.16.32.1
default: 201.33.4.2 (gw 201.33.4.1)
default to web: 179.16.32.2 (gw 179.16.32.1)
At 3.3 version on webproxy, even specifying the 179.16.32.2 as src-address the packages goes outside using 201.33.4.2.
This not happens using 2.9.x, and helped me a lot doing “cache full bandwidth” and lots more.
I tried doing a policy-routing to redirect even the 3128 traffic to the web gateway, but when I do this, the webpages stop responding..
Help me guys!
best regards from brazil,
vince (netsoares)
I have the some problem on my serwer.
I try everything and i can’t redirect traffic for secondary Wan.
Do you have any options?
My ver of ROS 3.3
Tom
You need to add two routing marks in mangle. Make sure these rules are numbers 0 and 1 in your mangle list.
/ip firewall mangle
add action=mark-routing chain=prerouting comment="" disabled=no dst-port=80 new-routing-mark=HTTP passthrough=yes protocol=tcp  place-before=0
add action=mark-routing chain=output comment="" disabled=no dst-port=80 new-routing-mark=HTTP passthrough=yes protocol=tcp  place-before=1
Now make a policy routing rule for HTTP.
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=179.16.32.1 routing-mark=HTTP scope=255 target-scope=10
Then create a lookup rule.
/ip route rule
add action=lookup comment="" disabled=no routing-mark=HTTP src-address=0.0.0.0/0 table=HTTP
That’s it!
Thank’s that is working, but somethimes connections is broken.
Web side is loding and is stop respodning.
Thanks for help.
Tom
I have another problem.
That is mangle:
/ip firewall mangle> print detail
0 ;;; HTTP
chain=prerouting action=mark-routing new-routing-mark=DSL1
passthrough=yes in-interface=LAN dst-port=80 protocol=tcp
1 chain=output action=mark-routing new-routing-mark=DSL1 passthrough=yes
2 ;;; Proxy
passthrough=yes in-interface=LAN dst-port=3128 protocol=tcp
3 chain=output action=mark-routing new-routing-mark=DSL1 passthrough=no
4 ;;; mark proxy traffic
chain=output action=mark-packet new-packet-mark=proxy-hit passthrough=no
out-interface=LAN dscp=4
5 ;;; ICMP
passthrough=no in-interface=LAN protocol=icmp
I got working web proxy on second wan but
I have another problem when I enable web proxy i have many times out connection.
Web sides loading and sometimes connections break and web side don’t responding.
What is the reson off that?
Thank’s for help.
Tom
