OK here is the setup
1 Mikrotik RB600
1 48v Poe
3 XR2
1 SR5
1 Trisector omni , 17dbi running channels 1,6,11. Each sector is 120 degrees
Remote hotspot being fed from a mountain that is fed from town
SO
Town >> mountain >> apt complex
Signal to town from mountain
Signal tx -60 rx -60
ccq 99%/99%
Signal to noise 30
Signal to apt from mountain
Signal tx -77 rx -77
ccq 99%/99%
Signal to noise 25
Here is the issue
The apt hotspot
I have 13 or so hotspots all connected to a main ap located in town. This particular hot spot is running 3.13. The users complain that they have to login to often, cause it logs them out and in sometimes every 5 mins or so. I have the timout set to off atm for testing purposes, i have the cookies set to 3d and etc
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
add dns-name=“” hotspot-address=10.5.20.1 html-directory=hotspot
mac,cookie,http-chap,http-pap mac-auth-password=“” name=hsprof1
nas-port-type=wireless-802.11 radius-accounting=yes radius-default-domain=
“” radius-interim-update=1m radius-location-id=“” radius-location-name=“”
rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
/ip hotspot
add address-pool=hs-pool-8 addresses-per-mac=5 disabled=no idle-timeout=none
interface=wifi keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default address-pool=hs-pool-8 idle-timeout=none keepalive-timeout=none
name=default shared-users=5 status-autorefresh=1m transparent-proxy=no
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add comment=“” disabled=no name=admin password=pitbull profile=default
/ip hotspot walled-garden
add action=allow comment=“” disabled=no dst-host=67.37.166.203
add action=allow comment=“” disabled=no dst-host=“:^www\.paypal\.com$”
dst-port=443
“:^content\.paypalobjects\.com$” dst-port=443
add action=allow comment=“” disabled=no dst-host=.akamaiedge.net
add action=allow comment=“” disabled=no dst-host=.myhost.com
add action=allow comment=“” disabled=no dst-host=67.166.79.251
/ip hotspot walled-garden ip
add action=accept comment=“” disabled=no dst-host=56.37.116.204
add action=accept comment=“” disabled=no dst-host=68.126.79.251
any ideas what it could be and better yet
Is ther a way to make so my users dont have to login but they still have the restrictions set to the user by my radius server.
