Help pleasse
Can somebody please post for me a working config for the above with load balancing capabilities i have tried the example given on the wiki but without much success. The traffic goes through one GAteway only (10.112.0.1)
ip address’‘’
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=wlan2
add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=wlan1
‘’‘/ ip firewall mangle’‘’
add chain=prerouting src-address-list=odd in-interface=Local action=mark-connection
new-connection-mark=odd passthrough=yes
add chain=prerouting src-address-list=odd in-interface=Local action=mark-routing
new-routing-mark=odd passthrough=no
add chain=prerouting src-address-list=even in-interface=Local action=mark-connection
new-connection-mark=even passthrough=yes
add chain=prerouting src-address-list=even in-interface=Local action=mark-routing
new-routing-mark=even passthrough=no
add chain=prerouting in-interface=Local connection-state=new nth=1,1,0
action=mark-connection new-connection-mark=odd passthrough=yes
add chain=prerouting in-interface=Local action=add-src-to-address-list
address-list=odd address-list-timeout=1d connection-mark=odd passthrough=yes
add chain=prerouting in-interface=Local connection-mark=odd action=mark-routing
add chain=prerouting in-interface=Local connection-state=new nth=1,1,1
action=mark-connection new-connection-mark=even passthrough=yes
address-list=even address-list-timeout=1d connection-mark=even passthrough=yes
add chain=prerouting in-interface=Local connection-mark=even action=mark-routing
add chain=srcnat src-address=192.168.0.0/24 action=masquerade
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 routing-mark=odd check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 routing-mark=even check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 distance=2
uauu 118 views and 0 replies
You haven’t provided enough information for help. What kind of Internet connection are you using? Is it connected via wireless? Can you ping both gateways from the router?
This is basic stuff. You should be able to read the manual and wiki and figure it out.
