i have 4 ethernet…with same network ( b class )
how can i drop connection from each ethernet…?
could you explain your problem in detail? and drop what connections?
@janisk thx for the respons…
here are the detail…
i have 3 ethernets with the config :
- ether1 - ip (10.10.0.251/16) - subnet (255.255.0.0) - static IP
- ether2 - ip (10.10.13.2/16) - subnet (255.255.0.0) - static IP
- ether3 - ip (192.168.4.1) - subnet (255.255.0.0) - dhcp IP
what i want to do is :
- clients from ether1 can not make a connection to ether 2 & 3
thx
just setup the firewall rules as per the manual…
Now that just plain doesn’t work… network 1 and network 2 are the same network. Go back to the drawing board!
/Jörgen
@joeri91942 sorry but i dont understand…?
@leequince can u tell me how the rule…?
hey…i did it…yuhuuuuuu
i just use bridging…and done…
thx y’ll
With two DIFFERENT network interfaces as this
You have one that is on the network 10.10.x.x (interface1, 10.10.0.251/16 ) and the second that is on network 10.10.x.x (interface 2, 10.10.13.2/16). These are BOTH on the same network… you are violating the most basic rules in IP and routing!
It’s like having Main Street to the left in an intersection AND also Main Street to right… but they are not the same Main Street! How would anyone know which Main Street a specific house number is on?
With bridging you actually connected the two Main Streets together so that they are the same street..
Please read a few primers on basic network design!
/Jörgen
@joeri91942 thx for the info…it’ss my mistake here is my new network design…
now i have 5 ether
ether 1 - > 10.10.0.251/16 (static clients / IP Local)
ether 2 - > 202.165.x.x/24 (IP Public)
ether 5 - > DHCP (IP Local)
i use bridging for ether 1-4…
i use difrent bridging for ether 5 (cause i want to use a dhcp)
