Help pls....OVPN i cant ping client
here the log…from my client pc…i cant see any connection to my microtik and i cant ping the client…any help pls…on mikrotik setup…???
Wed Feb 10 13:58:27 2010 us=891344 Current Parameter Settings:
Wed Feb 10 13:58:27 2010 us=900848 config = ‘/var/etc/openvpn/clientp2p.conf’
Wed Feb 10 13:58:27 2010 us=905355 mode = 0
Wed Feb 10 13:58:27 2010 us=908585 persist_config = DISABLED
Wed Feb 10 13:58:27 2010 us=910952 persist_mode = 1
Wed Feb 10 13:58:27 2010 us=915605 show_ciphers = DISABLED
Wed Feb 10 13:58:27 2010 us=918108 show_digests = DISABLED
Wed Feb 10 13:58:27 2010 us=920477 show_engines = DISABLED
Wed Feb 10 13:58:27 2010 us=928624 genkey = DISABLED
Wed Feb 10 13:58:27 2010 us=930957 key_pass_file = ‘[UNDEF]’
Wed Feb 10 13:58:27 2010 us=935799 show_tls_ciphers = DISABLED
Wed Feb 10 13:58:27 2010 us=938974 Connection profiles [default]:
Wed Feb 10 13:58:27 2010 us=941786 proto = udp
Wed Feb 10 13:58:27 2010 us=945136 local = ‘[UNDEF]’
Wed Feb 10 13:58:27 2010 us=947627 local_port = XXXXXXXXXX
Wed Feb 10 13:58:27 2010 us=950132 remote = XXXXXXXXXXXXXXX
Wed Feb 10 13:58:27 2010 us=952492 remote_port = XXXXXXXXXX
Wed Feb 10 13:58:27 2010 us=957203 remote_float = DISABLED
Wed Feb 10 13:58:27 2010 us=959721 bind_defined = DISABLED
Wed Feb 10 13:58:27 2010 us=961938 bind_local = ENABLED
Wed Feb 10 13:58:27 2010 us=966519 connect_retry_seconds = 5
Wed Feb 10 13:58:27 2010 us=969181 connect_timeout = 10
Wed Feb 10 13:58:27 2010 us=972152 connect_retry_max = 0
Wed Feb 10 13:58:27 2010 us=976634 socks_proxy_server = ‘[UNDEF]’
Wed Feb 10 13:58:27 2010 us=979021 socks_proxy_port = 0
Wed Feb 10 13:58:27 2010 us=981358 socks_proxy_retry = DISABLED
Wed Feb 10 13:58:27 2010 us=985091 Connection profiles END
Wed Feb 10 13:58:27 2010 us=987734 remote_random = DISABLED
Wed Feb 10 13:58:27 2010 us=990240 ipchange = ‘[UNDEF]’
Wed Feb 10 13:58:27 2010 us=992614 dev = ‘tun0’
Wed Feb 10 13:58:28 2010 us=393 dev_type = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=4378 dev_node = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=6703 lladdr = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=9175 topology = 1
Wed Feb 10 13:58:28 2010 us=11493 tun_ipv6 = DISABLED
Wed Feb 10 13:58:28 2010 us=16224 ifconfig_local = ‘10.10.1.10’
Wed Feb 10 13:58:28 2010 us=18587 ifconfig_remote_netmask = ‘10.10.10.7’
Wed Feb 10 13:58:28 2010 us=21691 ifconfig_noexec = DISABLED
Wed Feb 10 13:58:28 2010 us=26622 ifconfig_nowarn = DISABLED
Wed Feb 10 13:58:28 2010 us=29661 shaper = 0
Wed Feb 10 13:58:28 2010 us=31973 tun_mtu = 1500
Wed Feb 10 13:58:28 2010 us=35920 tun_mtu_defined = ENABLED
Wed Feb 10 13:58:28 2010 us=38311 link_mtu = 1500
Wed Feb 10 13:58:28 2010 us=40650 link_mtu_defined = DISABLED
Wed Feb 10 13:58:28 2010 us=45408 tun_mtu_extra = 0
Wed Feb 10 13:58:28 2010 us=48040 tun_mtu_extra_defined = DISABLED
Wed Feb 10 13:58:28 2010 us=50412 fragment = 0
Wed Feb 10 13:58:28 2010 us=55357 mtu_discover_type = -1
Wed Feb 10 13:58:28 2010 us=58547 mlock = DISABLED
Wed Feb 10 13:58:28 2010 us=61332 keepalive_ping = 0
Wed Feb 10 13:58:28 2010 us=64677 keepalive_timeout = 0
Wed Feb 10 13:58:28 2010 us=67651 inactivity_timeout = 0
Wed Feb 10 13:58:28 2010 us=70011 ping_send_timeout = 0
Wed Feb 10 13:58:28 2010 us=72516 ping_rec_timeout = 0
Wed Feb 10 13:58:28 2010 us=85403 ping_rec_timeout_action = 0
Wed Feb 10 13:58:28 2010 us=87901 ping_timer_remote = DISABLED
Wed Feb 10 13:58:28 2010 us=90415 remap_sigusr1 = 0
Wed Feb 10 13:58:28 2010 us=98549 persist_tun = DISABLED
Wed Feb 10 13:58:28 2010 us=101307 persist_local_ip = DISABLED
Wed Feb 10 13:58:28 2010 us=104905 persist_remote_ip = DISABLED
Wed Feb 10 13:58:28 2010 us=107570 persist_key = DISABLED
Wed Feb 10 13:58:28 2010 us=110073 mssfix = 1450
Wed Feb 10 13:58:28 2010 us=112260 passtos = DISABLED
Wed Feb 10 13:58:28 2010 us=117149 resolve_retry_seconds = 1000000000
Wed Feb 10 13:58:28 2010 us=119531 username = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=121865 groupname = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=126228 chroot_dir = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=128926 cd_dir = ‘/var/etc/openvpn’
Wed Feb 10 13:58:28 2010 us=131782 writepid = ‘/var/run/openvpn.clientp2p.pid’
Wed Feb 10 13:58:28 2010 us=138408 up_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=141338 down_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=146004 down_pre = DISABLED
Wed Feb 10 13:58:28 2010 us=148359 up_restart = DISABLED
Wed Feb 10 13:58:28 2010 us=150719 up_delay = DISABLED
Wed Feb 10 13:58:28 2010 us=154050 daemon = ENABLED
Wed Feb 10 13:58:28 2010 us=156677 inetd = 0
Wed Feb 10 13:58:28 2010 us=159174 log = ENABLED
Wed Feb 10 13:58:28 2010 us=161512 suppress_timestamps = DISABLED
Wed Feb 10 13:58:28 2010 us=166370 nice = 0
Wed Feb 10 13:58:28 2010 us=168843 verbosity = 5
Wed Feb 10 13:58:28 2010 us=171188 mute = 0
Wed Feb 10 13:58:28 2010 us=176171 gremlin = 0
Wed Feb 10 13:58:28 2010 us=179344 status_file = ‘/var/run/openvpn.clientp2p.status’
Wed Feb 10 13:58:28 2010 us=182061 status_file_version = 1
Wed Feb 10 13:58:28 2010 us=185603 status_file_update_freq = 10
Wed Feb 10 13:58:28 2010 us=188530 rcvbuf = 65536
Wed Feb 10 13:58:28 2010 us=190851 sndbuf = 65536
Wed Feb 10 13:58:28 2010 us=198381 sockflags = 0
Wed Feb 10 13:58:28 2010 us=200841 fast_io = DISABLED
Wed Feb 10 13:58:28 2010 us=204923 lzo = 0
Wed Feb 10 13:58:28 2010 us=207086 route_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=209446 route_default_gateway = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=211996 route_default_metric = 0
Wed Feb 10 13:58:28 2010 us=216778 route_noexec = DISABLED
Wed Feb 10 13:58:28 2010 us=219153 route_delay = 0
Wed Feb 10 13:58:28 2010 us=222080 route_delay_window = 30
Wed Feb 10 13:58:28 2010 us=225637 route_delay_defined = DISABLED
Wed Feb 10 13:58:28 2010 us=228566 route_nopull = DISABLED
Wed Feb 10 13:58:28 2010 us=230941 route_gateway_via_dhcp = DISABLED
Wed Feb 10 13:58:28 2010 us=236288 max_routes = 100
Wed Feb 10 13:58:28 2010 us=238603 allow_pull_fqdn = DISABLED
Wed Feb 10 13:58:28 2010 us=240981 management_addr = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=244617 management_port = 0
Wed Feb 10 13:58:28 2010 us=246826 management_user_pass = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=249347 management_log_history_cache = 250
Wed Feb 10 13:58:28 2010 us=252178 management_echo_buffer_size = 100
Wed Feb 10 13:58:28 2010 us=257266 management_write_peer_info_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=260291 management_client_user = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=265099 management_client_group = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=267807 management_flags = 0
Wed Feb 10 13:58:28 2010 us=270169 shared_secret_file = ‘/var/etc/openvpn/vpnkeys/client1.key’
Wed Feb 10 13:58:28 2010 us=275439 key_direction = 0
Wed Feb 10 13:58:28 2010 us=277941 ciphername_defined = ENABLED
Wed Feb 10 13:58:28 2010 us=280485 ciphername = ‘BF-CBC’
Wed Feb 10 13:58:28 2010 us=285205 authname_defined = ENABLED
Wed Feb 10 13:58:28 2010 us=287702 authname = ‘SHA1’
Wed Feb 10 13:58:28 2010 us=290843 prng_hash = ‘SHA1’
Wed Feb 10 13:58:28 2010 us=300478 prng_nonce_secret_len = 16
Wed Feb 10 13:58:28 2010 us=303650 keysize = 0
Wed Feb 10 13:58:28 2010 us=305823 engine = DISABLED
Wed Feb 10 13:58:28 2010 us=308329 replay = ENABLED
Wed Feb 10 13:58:28 2010 us=310683 mute_replay_warnings = DISABLED
Wed Feb 10 13:58:28 2010 us=315439 replay_window = 64
Wed Feb 10 13:58:28 2010 us=318167 replay_time = 15
Wed Feb 10 13:58:28 2010 us=320378 packet_id_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=325106 use_iv = ENABLED
Wed Feb 10 13:58:28 2010 us=327588 test_crypto = DISABLED
Wed Feb 10 13:58:28 2010 us=329931 tls_server = DISABLED
Wed Feb 10 13:58:28 2010 us=332426 tls_client = DISABLED
Wed Feb 10 13:58:28 2010 us=337068 key_method = 2
Wed Feb 10 13:58:28 2010 us=339423 ca_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=341940 ca_path = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=345482 dh_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=348400 cert_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=350770 priv_key_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=356207 pkcs12_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=358591 cipher_list = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=364211 tls_verify = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=366742 tls_remote = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=369398 crl_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=371789 ns_cert_type = 0
Wed Feb 10 13:58:28 2010 us=376850 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=380069 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=382460 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=386991 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=389863 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=392237 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=398544 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=400925 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=406111 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=408603 remote_cert_ku = 0
Wed Feb 10 13:58:28 2010 us=411110 remote_cert_ku[i] = 0
Wed Feb 10 13:58:28 2010 us=430329 remote_cert_ku[i] = 0
Wed Feb 10 13:58:28 2010 us=434196 remote_cert_ku[i] = 0
Wed Feb 10 13:58:28 2010 us=436951 remote_cert_ku[i] = 0
Wed Feb 10 13:58:28 2010 us=439481 remote_cert_ku[i] = 0
Wed Feb 10 13:58:28 2010 us=441850 remote_cert_ku[i] = 0
Wed Feb 10 13:58:28 2010 us=446714 remote_cert_eku = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=449240 tls_timeout = 2
Wed Feb 10 13:58:28 2010 us=452078 renegotiate_bytes = 0
Wed Feb 10 13:58:28 2010 us=456610 renegotiate_packets = 0
Wed Feb 10 13:58:28 2010 us=459147 renegotiate_seconds = 3600
Wed Feb 10 13:58:28 2010 us=461693 handshake_window = 60
Wed Feb 10 13:58:28 2010 us=465515 transition_window = 3600
Wed Feb 10 13:58:28 2010 us=468010 single_session = DISABLED
Wed Feb 10 13:58:28 2010 us=470521 tls_exit = DISABLED
Wed Feb 10 13:58:28 2010 us=475491 tls_auth_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=478458 server_network = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=481035 server_netmask = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=485225 server_bridge_ip = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=487915 server_bridge_netmask = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=490333 server_bridge_pool_start = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=497659 server_bridge_pool_end = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=500639 ifconfig_pool_defined = DISABLED
Wed Feb 10 13:58:28 2010 us=505319 ifconfig_pool_start = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=508438 ifconfig_pool_end = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=510886 ifconfig_pool_netmask = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=514876 ifconfig_pool_persist_filename = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=517446 ifconfig_pool_persist_refresh_freq = 600
Wed Feb 10 13:58:28 2010 us=520134 n_bcast_buf = 256
Wed Feb 10 13:58:28 2010 us=522488 tcp_queue_limit = 64
Wed Feb 10 13:58:28 2010 us=527738 real_hash_size = 256
Wed Feb 10 13:58:28 2010 us=530081 virtual_hash_size = 256
Wed Feb 10 13:58:28 2010 us=532610 client_connect_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=538159 learn_address_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=541028 client_disconnect_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=544513 client_config_dir = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=547670 ccd_exclusive = DISABLED
Wed Feb 10 13:58:28 2010 us=550174 tmp_dir = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=552539 push_ifconfig_defined = DISABLED
Wed Feb 10 13:58:28 2010 us=557384 push_ifconfig_local = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=559975 push_ifconfig_remote_netmask = 0.0.0.0
Wed Feb 10 13:58:28 2010 us=562520 enable_c2c = DISABLED
Wed Feb 10 13:58:28 2010 us=567039 duplicate_cn = DISABLED
Wed Feb 10 13:58:28 2010 us=569696 cf_max = 0
Wed Feb 10 13:58:28 2010 us=575027 cf_per = 0
Wed Feb 10 13:58:28 2010 us=577564 max_clients = 1024
Wed Feb 10 13:58:28 2010 us=580896 max_routes_per_client = 256
Wed Feb 10 13:58:28 2010 us=584368 auth_user_pass_verify_script = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=586905 auth_user_pass_verify_script_via_file = DISABLED
Wed Feb 10 13:58:28 2010 us=589448 ssl_flags = 0
Wed Feb 10 13:58:28 2010 us=591801 port_share_host = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=599697 port_share_port = 0
Wed Feb 10 13:58:28 2010 us=604156 client = DISABLED
Wed Feb 10 13:58:28 2010 us=606501 pull = DISABLED
Wed Feb 10 13:58:28 2010 us=609147 auth_user_pass_file = ‘[UNDEF]’
Wed Feb 10 13:58:28 2010 us=611954 OpenVPN 2.1.1 sh4-linux-gnu [SSL] [LZO2] [EPOLL] built on Dec 14 2009
Wed Feb 10 13:58:28 2010 us=618368 NOTE: OpenVPN 2.1 requires ‘–script-security 2’ or higher to call user-defined scripts or executables
Wed Feb 10 13:58:28 2010 us=630340 WARNING: file ‘/var/etc/openvpn/vpnkeys/client1.key’ is group or others accessible
Wed Feb 10 13:58:28 2010 us=635554 Static Encrypt: Cipher ‘BF-CBC’ initialized with 128 bit key
Wed Feb 10 13:58:28 2010 us=638935 Static Encrypt: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Feb 10 13:58:28 2010 us=645198 Static Decrypt: Cipher ‘BF-CBC’ initialized with 128 bit key
Wed Feb 10 13:58:28 2010 us=648048 Static Decrypt: Using 160 bit message hash ‘SHA1’ for HMAC authentication
Wed Feb 10 13:58:28 2010 us=663595 TUN/TAP device tun0 opened
Wed Feb 10 13:58:28 2010 us=666231 TUN/TAP TX queue length set to 100
Wed Feb 10 13:58:28 2010 us=669970 /sbin/ifconfig tun0 10.10.1.10 pointopoint 10.10.10.7 mtu 1500
Wed Feb 10 13:58:28 2010 us=701763 Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:4 ET:0 EL:0 ]
Wed Feb 10 13:58:28 2010 us=715992 Socket Buffers: R=[105472->131072] S=[105472->131072]
Wed Feb 10 13:58:28 2010 us=719204 UDPv4 link local (bound): [undef]:XXXXXX
Wed Feb 10 13:58:28 2010 us=721845 UDPv4 link remote: XXXXXXXXXXX:XXXXXX
ok..now i got same think..but there’s a missing config on mikrotik server side
WWed Feb 10 16:06:52 2010 us=930173 read UDPv4 [ECONNREFUSED]: Connection refused (code=111)
RWWed Feb 10 16:06:54 2010 us=568777 read UDPv4 [ECONNREFUSED]: Connection refused (code=111)
RWWed Feb 10 16:06:57 2010 us=169929 read UDPv4 [ECONNREFUSED]: Connection refused (code=111)
RWWed Feb 10 16:06:58 2010 us=791006 read UDPv4 [ECONNREFUSED]: Connection refused (code=111)
RWWed Feb 10 16:07:01 2010 us=609514 read UDPv4 [ECONNREFUSED]: Connection refused (code=111)
ok now ,i got this …bloody error numbers…all shits
read UDPv4 [EHOSTUNREACH|EHOSTUNREACH]: No route to host (code=113)
RWWWed Feb 10 16:11:22 2010 us=216920 read UDPv4 [EHOSTUNREACH|EHOSTUNREACH]: No route to host (code=113)
any body can comment …pls…cos i’m going to take my head of now…
