[HELP] PPPoE + Load Balancing PCC + Port Forwarding
I’m having issues with port forwarding. It doesn’t work.
Please help.
This is my setup:
ip address print detail
 0   address=192.168.254.2/24 network=192.168.254.0
     interface=Yudheng Internet 1 actual-interface=Yudheng Internet 1
 1   address=192.168.2.1/24 network=192.168.2.0 interface=Yudheng LAN
     actual-interface=Yudheng LAN
 2   address=192.168.253.2/24 network=192.168.253.0
     interface=Yudheng Internet 2 actual-interface=Yudheng Internet 2
 3 D address=130.136.177.108/32 network=130.136.176.1 interface=Speedy2
     actual-interface=Speedy2
 4 D address=180.245.204.217/32 network=180.245.204.1 interface=Speedy1
     actual-interface=Speedy1
ip route print detail
 0 A S  dst-address=0.0.0.0/0 gateway=180.245.204.1
        gateway-status=180.245.204.1 reachable via  Speedy1
        check-gateway=ping distance=1 scope=30 target-scope=10
        routing-mark=to_internet1
 1 A S  dst-address=0.0.0.0/0 gateway=130.136.176.1
        gateway-status=130.136.176.1 reachable via  Speedy2
        routing-mark=to_internet2
 2 A S  dst-address=0.0.0.0/0 gateway=180.245.204.1
 3   S  dst-address=0.0.0.0/0 gateway=130.136.176.1
        check-gateway=ping distance=2 scope=30 target-scope=10
 4 ADC  dst-address=130.136.176.1/32 pref-src=130.136.177.108 gateway=Speedy2
        gateway-status=Speedy2 reachable distance=0 scope=10
 5 ADC  dst-address=180.245.204.1/32 pref-src=180.245.204.217 gateway=Speedy1
        gateway-status=Speedy1 reachable distance=0 scope=10
 6 ADC  dst-address=192.168.2.0/24 pref-src=192.168.2.1 gateway=Yudheng LAN
        gateway-status=Yudheng LAN reachable distance=0 scope=10
 7 ADC  dst-address=192.168.253.0/24 pref-src=192.168.253.2
        gateway=Yudheng Internet 2
        gateway-status=Yudheng Internet 2 reachable distance=0 scope=10
 8 ADC  dst-address=192.168.254.0/24 pref-src=192.168.254.2
        gateway=Yudheng Internet 1
        gateway-status=Yudheng Internet 1 reachable distance=0 scope=10
 interface print detail
 0  R  name="Speedy1" type="pppoe-out" mtu=1480
 1  R  name="Yudheng LAN" type="ether" mtu=1500
 2  R  name="Yudheng Internet 2" type="ether" mtu=1500
 3  R  name="Yudheng Internet 1" type="ether" mtu=1500
 4  R  name="Speedy2" type="pppoe-out" mtu=1480
ip firewall nat print
 0   chain=srcnat action=masquerade out-interface=Speedy1
 1   chain=srcnat action=masquerade out-interface=Speedy2
 2   chain=dstnat action=dst-nat to-addresses=192.168.2.75 to-ports=8075
     protocol=tcp dst-address=180.245.204.217 dst-address-type=local
     dst-port=8075 port=""
 ip firewall mangle print
 0   chain=output action=mark-routing new-routing-mark=to_internet1
     passthrough=yes connection-mark=internet1_conn
 1   chain=output action=mark-routing new-routing-mark=to_internet2
     passthrough=yes connection-mark=internet2_conn
 2   chain=prerouting action=accept dst-address=180.245.204.1
     in-interface=Yudheng LAN
 3   chain=prerouting action=accept dst-address=130.136.176.1
 4   chain=input action=mark-connection new-connection-mark=internet1_conn
     passthrough=yes in-interface=Speedy1 connection-mark=no-mark
 5   chain=input action=mark-connection new-connection-mark=internet2_conn
     passthrough=yes in-interface=Speedy2 connection-mark=no-mark
 6   chain=prerouting action=mark-connection new-connection-mark=internet1_con>
     passthrough=yes dst-address-type=!local in-interface=Yudheng LAN
     connection-mark=no-mark per-connection-classifier=both-addresses:2/0
 7   chain=prerouting action=mark-connection new-connection-mark=internet2_con>
     connection-mark=no-mark per-connection-classifier=both-addresses:2/1
 8   chain=prerouting action=mark-routing new-routing-mark=to_internet1
     passthrough=yes in-interface=Yudheng LAN connection-mark=internet1_conn
 9   chain=prerouting action=mark-routing new-routing-mark=to_internet2
     passthrough=yes in-interface=Yudheng LAN connection-mark=internet2_conn
Please help.
please help… :smiley: :smiley:
any body here?
