[HELP] PPPOE server and client low throughput
Hey Guys,
i upgraded my local node to the latest firmware the current release, ever since i did that my internet speeds on my own network went from 400mbit down and 40 up to 40mbit down and 40mbit up.
i also tested it from the server subnet which is running over static ip’s instead of pppoe, i did not get the change yet to test on of the customers routers yet to see if they got the same issue but here is the setup
Mikrotik CCR1036-16-EM (BGP, PPPOE, DHCP)
Ubiquiti Switch (ES-16-XG)
Mikrotik CCR1009-RM (PPPOE CLIENT) == 40mbit/40mbit used to be 400mbit/40mbit before the upgrade
i already checked queue and even with queue disabled its still wont go above 40mbits download.
did they change something in the PPPOE-Server / PPPOE-Client that would explane this? i also use a bridge with VLANs on the bridge the new way, i suspect the bridge rewriting has something to do with this but after reverting the upgrade its still a issue
tried another firmware but no effect, is there no body that has similar issues?
Also tried to see if changing from bridge to lan helps but is doesn’t also tried to see if it helped if i when static but it did not help. its a CCR1009 RM that has the issue, and i can’t seem to find out why
