aleab
May 26, 2022, 6:47pm
1
i want to monitor a mikrotik load balancer (pcc) with ip on wan natted.
so i can’t monitor from outside mikrotik.
i can monitor mikrotik 4011 from a remote chr on datacenter with VPN.
works all fine, but i want to check if a wan is down
so, if a run on terminal in 4011
:put ([:pick [/tool netwatch print as-value where comment="MONITOR - WAN1"] 0]->"status");
result is up or down
i try to integrate this ros command in dude to monitor if a wan is down
so i create a function
code:
ros_command(":put ([:pick [/tool netwatch print as-value where comment=\"MONITOR WAN1\"] 0]->\"status\");")
i used \ to escape double quotes
create probes
type: function
agent: default
available : 1=1
error : if(mikrotik_netwatch_wan1()=up, “”, “down”)
value: mikrotik_netwatch_wan1()
unit: [empty]
but when i add this probe to device i have “parse failed”
some can help to improve this monitoring?
thank you in advance
aleab
May 27, 2022, 6:35pm
2
i think parse failed is a problem in functions.
so i try also
if (ros_command(":put ([:pick [/tool netwatch print as-value where comment=\"MONITOR WAN1\"] 0]->\"status\");")) = "up", "", "down")
but i have same problem “parse failed”
i try also with host
if (ros_command(":put ([:pick [/tool netwatch print as-value where host=8.8.8.8] 0]->\"status\");")) = "up", "", "down")
thank you
Simply count parenthesys outside put string?
2 (
3 )
if ( ros_command(":put ([/tool netwatch print as-value where comment=\"MONITOR WAN1\"]->0->\"status\")") = "up", "", "down" )
aleab
May 28, 2022, 7:25pm
4
thank you for reply.
i check on mikrotik and yes , your code is more clean and works
but when i change on dude i receive always “parse failed”
maybe error is on probe???
type: function
agent: default
available : 1=1
unit: [empty]
i tried also
error : if(mikrotik_netwatch_wan1()==up, “”, “down”)
thank you again
aleab
May 29, 2022, 12:10pm
5
i check another way , and change function like this
i add it in appearance and i show correct : up
so now i’m sure problem is on probe
i create probe
available: 1
error: if(mikrotik_function_netwatch_wan1()==up, “”, “down”)
value: mikrotik_function_netwatch_wan1()
also
error: if(mikrotik_function_netwatch_wan1()=up, “”, “down”)
parse error
aleab
June 6, 2022, 6:39pm
6
nothing, i try many code but with the dude i have always same error…
to reader, i resolve with zabbix…
i monitor netwatch with zabbix and ssh agent (of course i need to enable and expose ssh port, but i open only from my zabbix ip)
ps. @rextended , can i contact you in private?
i need some help with a request of my customer and i’m searching a professional help (payment of course)
thank you
