HELP - Problems with Radius when running Hotspot with ECMP
When I run hotspot on 2.8.26 with radius on a single internet connection everything works fine; but when I try to load balance, radius does not respond. For users already authenticated, the load balancing works fine, but there is no response from radius for authentication (:1812) and accounting (:1813). Packet sniffer shows that the the auth and acct packets are being sent out, but there are no incoming packets from the radius server.
Can someone running this type of setup offer any help? I would be willing to pay for your time if you can fix the problem.
