HELP: Publish Server over 2 Mikrotik router? Is it possible?
Currently I use mikrotik router OS 2.8.9. with Internet IP Gateway is 202.148.1.145/29, and Mikrotik router IP is 202.148.1.146/29. I have Local Network (A) with IP address is 192.168.0.0/24.
I have another Local network (B) with IP 192.168.100.0/24. Then I connect the B network to A network with Mikrotik router too. So I have 2 mikrotik router. First for router between Public network with “A” Network, and second for router between “A” Network with “B” Network.
It’s already works. Users on network “B” already could browsing and uses the internet.
The problem is now, I have a web server on Network B with IP 192.168.100.100. How to routing and publish the web server?
Or maybe I have mail server too, how to publish it?
Thank’s in advanced.
You should use destination NAT. You can read about it at:
http://www.mikrotik.com/docs/ros/2.8/ip/nat.main
