--HELP-- Queue for web with webproxy
Can someone tell me how to limit and shape (queue) web downloads?
I wanna add a mangle to mark web traffic and limit that marked packet in queue. but the problem is I’m using web proxy as well (to speed up webpage opening, and also blocking some web sites)
don’t know if this is possible or not ?
WebProxy traffic should be marked in ‘output’ chain, not ‘forward’ or ‘prerouting’
It works, but smth else is missing, I created the mangle rule like this :
Ip firewall mangle print
 0   chain=output action=mark-packet new-packet-mark=tst passthrough=yes
     protocol=tcp dst-address=192.168.0.79 src-port=8080
and then went on and created this queue:
 queue simple print
 0    name="queue1" interface=all parent=none packet-marks=tst direction=both
      priority=8 queue=default-small/default-small limit-at=0/0 max-limit=0/0
      burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
      total-queue=default-small
but that doesn’t work, It should show some traffic passing but it aint.
any ideas?
this should be limiting the traffic coming from web proxy, so I can limit a number of high downloading users, but don’t wanna limit the server and resources connections.
your queue won’t work just because you haven’t changed nothing in its parameters
you’d better use Queue Tree
Or set the limit-at parameter to 1g/1g for Gigabit Ethernet wirespeed. That way the queue can grab the traffic and exempt it from lower queues, but it won’t effectively do anything.
hi i need some info about caching
is there posible to use mikrotik as a external cacche server like linux squid
if there is plz tell me the solution
i m running X86 machine with several bridges wds bridges
i want to use mikrotik as external web caching server
plz help
