Hey there, I’m trying to configure a PtP link between two points, doesn’t matter the distances right now because I even don’t know how to configure the two points for the link, so I need help on this first.
Actually I’m using WinBox to configure the boards, but if its better I could use the terminal.
In wireless configuration I don’t know if I need to setup a SSID, the Mode (station, ap bridge, bridge, etc…) to setup. Also I don’t know if I need to enable WDS, or even use Nstream.
I recommend you to start from wireless documentation, http://www.mikrotik.com/testdocs/ros/2.9/interface/wireless.php
basic AP-station configuration examples is provided there.
WDS is not required for your unless you do not need to create transparent bridge over wireless network or connect one AP to another.
You also have take in account that any of those security profiles makes throughput lesser, I use MAC filter anyway.
I have one 6kms ptp link and another (for now) of 2kms, same.
