Help....rb133 load balance 3wifi links in one ethernet
Hello i dont have much knowledge of this stuff
i have a rb133 and i am trying to connect 3 station wifi links in one ethernet
Strange things happen but the thing doesnt work smoothly
Thing goes a little better when wifi links are queued at low speeds
I have tried ecmp nth and pcc
Also since i dont have full control of what ip wifi routers give
i want to transfer their ip to another my own
Whats the best way to do it?
There maybe be childish mistakes in my scripts so i ask your understanding
DNS and DHCP for ethernet are configured (or so i would like to believe)
Here is what i use in pcc
add address=192.168.1.11/24 disabled=no interface=WAN1 network=192.168.1.0
add address=192.168.2.11/24 disabled=no interface=WAN2 network=192.168.2.0
add address=10.5.50.255/24 disabled=no interface=WAN3 network=10.5.50.0
add address=20.5.50.1/24 disabled=no interface=Local network=20.5.50.0
/ip firewall mangle
add action=mark-connection chain=input connection-state=new disabled=no
in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=yes
in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=yes
in-interface=WAN3 new-connection-mark=WAN3_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn disabled=no
new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn disabled=no
new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN3_conn disabled=no
new-routing-mark=to_WAN3 passthrough=yes
add action=accept chain=prerouting disabled=no dst-address=192.168.1.0/24
in-interface=Local
add action=accept chain=prerouting disabled=no dst-address=192.168.2.0/24
in-interface=Local
add action=accept chain=prerouting disabled=no dst-address=10.5.50.0/24
in-interface=Local
add action=mark-connection chain=prerouting disabled=no dst-address-type=
!local in-interface=Local new-connection-mark=WAN1_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:3/0
!local in-interface=Local new-connection-mark=WAN2_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:3/1
!local in-interface=Local new-connection-mark=WAN3_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=WAN1_conn disabled=
no in-interface=Local new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn disabled=
no in-interface=Local new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN3_conn disabled=
no in-interface=Local new-routing-mark=to_WAN3 passthrough=yes
add action=mark-connection chain=prerouting disabled=no dst-address=
192.168.1.0/24 in-interface=WAN1 new-connection-mark=wlan1 passthrough=
yes
10.5.50.0/24 in-interface=WAN3 new-connection-mark=wlan3 passthrough=yes
192.168.2.0/24 in-interface=WAN2 new-connection-mark=wlan2 passthrough=
yes
add action=mark-packet chain=prerouting connection-mark=wlan1 disabled=no
dst-address=192.168.1.0/24 in-interface=WAN1 new-packet-mark=wlan11
passthrough=yes
add action=mark-packet chain=prerouting connection-mark=wlan2 disabled=no
dst-address=192.168.2.0/24 in-interface=WAN2 new-packet-mark=wlan22
passthrough=yes
add action=mark-packet chain=prerouting connection-mark=wlan3 disabled=no
dst-address=10.5.50.0/24 in-interface=WAN3 new-packet-mark=wlan33
passthrough=yes
add action=masquerade chain=srcnat disabled=no out-interface=WAN1
add action=masquerade chain=srcnat disabled=no out-interface=WAN2
add action=masquerade chain=srcnat disabled=no out-interface=WAN3
to-addresses=0.0.0.0
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
192.168.1.1 routing-mark=to_WAN1 scope=30 target-scope=10
add check-gateway=ping disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=
192.168.2.1 routing-mark=to_WAN2 scope=30 target-scope=10
10.5.50.1 routing-mark=to_WAN3 scope=30 target-scope=10
192.168.1.1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=
192.168.2.1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=3 dst-address=0.0.0.0/0 gateway=
10.5.50.1 scope=30 target-scope=10
in ecmp…
add address=192.168.0.1/24 disabled=no interface=ether1 network=192.168.0.0
add address=192.168.2.2/24 disabled=no interface=wlan2 network=192.168.2.0
add address=192.168.1.2/24 disabled=no interface=wlan3 network=192.168.1.0
add address=10.5.50.2/24 disabled=no interface=wlan1 network=10.5.50.0
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=wlan1
new-connection-mark=wlan1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan2
new-connection-mark=wlan2_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan3
new-connection-mark=wlan3_conn passthrough=yes
add action=mark-routing chain=output connection-mark=wlan1_conn disabled=no
new-routing-mark=to_wla1 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan2_conn disabled=no
new-routing-mark=to_wla2 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan3_conn disabled=no
new-routing-mark=to_wla3 passthrough=yes
add action=mark-connection chain=prerouting disabled=no in-interface=wlan1
new-connection-mark=wlan11 passthrough=yes
add action=mark-connection chain=prerouting disabled=no in-interface=wlan2
new-connection-mark=wlan22 passthrough=yes
add action=mark-connection chain=prerouting disabled=no in-interface=wlan3
new-connection-mark=wlan33 passthrough=yes
add action=mark-packet chain=prerouting connection-mark=wlan11 disabled=no
in-interface=wlan1 new-packet-mark=wlan11 passthrough=yes
add action=mark-packet chain=prerouting connection-mark=wlan33 disabled=no
in-interface=wlan3 new-packet-mark=wlan33 passthrough=yes
add action=mark-packet chain=prerouting connection-mark=wlan22 disabled=no
in-interface=wlan2 new-packet-mark=wlan22 passthrough=yes
add action=masquerade chain=srcnat disabled=no out-interface=wlan1
add action=masquerade chain=srcnat disabled=no out-interface=wlan2
add action=masquerade chain=srcnat disabled=no out-interface=wlan3
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.5.50.1
routing-mark=to_wla1 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.1
routing-mark=to_wla2 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1
routing-mark=to_wla3 scope=30 target-scope=10
192.168.2.1,192.168.1.1,10.5.50.1 scope=30 target-scope=10
My nth configuration doesnt work so nothing to post on that
Anyone???
Is rb133 at 175mhz cpu too small to do load balancing?
trying to balance two 2mbps and one 4mbps
All my lines wont stay up all the time
Cpu load goes up to 80-90% before one line drops
Yeah, way to small to do any real routing/load balancing
