Help! RB230 - unable to boot ROS from CF card
Folks,
I’m struggling to boot my RB230 from the CF card.
Installed ROS using NetInstall (Etherboot), have tried both 2.9.50 and 3.0rc13.
The router recognizes the CF card and appears to install ROS properly, but I’m unable to boot.
As CF is recognized, why isn’t it listed as a boot option in BIOS?
As the RB installs on the CF card it should be able to boot on it?
Or is booting only possible from an IDE interface? If yes, what is CF usable for?
Anyone?
RouterBIOS-200 v1.3.7 MikroTik (tm) 2003-2005
RouterBOARD 230r3 (CPU revision B1)
CPU frequency: 266 MHz
  Memory size: 128 MB
Press any key within 1 second to enter setup.
What do you want to configure?
   d - boot delay
   k - boot key
   s - serial console
   l - debug level
   o - boot device
   b - beep on boot
   v - vga to serial
   t - ata translation
   p - memory settings
   m - memory test
   u - cpu mode
   f - pci back-off
   r - reset configuration
   g - bios upgrade through serial port
   i - board info
   c - bios license information
   x - exit setup
your choice: o - boot device
Select boot device:
 * i - IDE
   e - Etherboot
   1 - Etherboot (timeout 15s), IDE
   2 - Etherboot (timeout  1m), IDE
   3 - Etherboot (timeout  5m), IDE
   4 - Etherboot (timeout 30m), IDE
   5 - IDE, try Etherboot first on next boot (15s)
   6 - IDE, try Etherboot first on next boot (1m)
   7 - IDE, try Etherboot first on next boot (5m)
   8 - IDE, try Etherboot first on next boot (30m)
your choice: 2 - Etherboot (timeout  1m), IDE
   d - boot delay
   k - boot key
   s - serial console
   l - debug level
   o - boot device
   b - beep on boot
   v - vga to serial
   t - ata translation
   p - memory settings
   m - memory test
   u - cpu mode
   f - pci back-off
   i - board info
   x - exit setup
your choice: x - exit setup
  Memory size: 128 MB
Press any key within 1 second to enter setup..
Booting Etherboot...
Ether1...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................done
[?25l[H[2JWelcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:03:9C:9D
mac-address: 00:0C:42:03:9C:9E
Waiting for drivers...
Retrieving drivers...
Loading drivers
Looking for harddrives...
Found harddrive as IDE Primary master (disk C)
disk label: mikrotik
software-id: WG4U-E1N
Waiting for installation server...
Found server at 00:90:4B:AD:8E:9C
Creating partition........
Formatting disk...............................
Writing configuration...
Software installed.
Press ENTER to reboot
[?þ
  Memory size: 128 MB
   d - boot delay
   k - boot key
   s - serial console
   l - debug level
   o - boot device
   b - beep on boot
   v - vga to serial
   t - ata translation
   p - memory settings
   m - memory test
   u - cpu mode
   f - pci back-off
   i - board info
   x - exit setup
Select boot device:
   i - IDE
   e - Etherboot
 * 2 - Etherboot (timeout  1m), IDE
your choice: i - IDE
   d - boot delay
   k - boot key
   s - serial console
   l - debug level
   o - boot device
   b - beep on boot
   v - vga to serial
   t - ata translation
   p - memory settings
   m - memory test
   u - cpu mode
   f - pci back-off
   i - board info
   x - exit setup
  Memory size: 128 MB
Booting IDE...
Missing operating system
Check JP2! It must be close. If problem still present try with other CF
Well, it is actually closed…:frowning:
RB230 is new to me, I need a confirmation that it is able to boot from CF!
If all the installation using Netinstall goes fine, then the card must be ok? Then, why won’t it boot from it, and how can it help repeating the procedure on another CF card?
Any tips? I don’t like the idea of adding a “real” IDE HDD, and if CF booting is possible, buying IDE flash should not be necessary.
Anyone from Mikrotik that can comment on this?
Normis?
Sorry for nagging you, but as this is a board still delivered by MT there must be somebody within MT or among users that has been playing around with it enough to be able to help?
Unfortunately I’m stuck on this… :frowning:
You have to select IDE to use Either IDE of CF. there is no separate selection, sorry for confusion :slight_smile:
Thank you Normis.
As I wrote, installing ROS on the CF goes all fine, but it won’t boot from it, despite JP2 is closed.
Can you please comment on the console output above?
Trying another CF was mentioned. Is it possible that one functioning card is bootable, while another is not?
did you select “boot from IDE” in BIOS or not?
Yes, you can see it close to the end of the console output, I selected “i” for IDE and then “x” to reboot. However the board (bios) does not recognize the CF.
If you have a spare CF of another kind/brand, please try that and see if it works with that one.
Ordered another card (Lexar, first one was Twinmos) and tried it today, but same result.
I’m getting kind of frustrated now.
Is there anybody out there that can confirm that booting from CF is possible? :open_mouth:
Have you tried it yourselves?
Something I have overlooked?
Please somebody, otherwise my new RB230 will end in the scrapyard, I don’t think it deserves so… :frowning:
Of course, we have loads of these devices and they all work from CF only. We even installed a new one just now, just to test this.
So you tried all jumpers and all BIOS settings? Did you try a laptiop IDE drive just to see if it can boot at all?
JP1 - Open : Normal operation (otherwise the RB would reboot!)
JP2 - Closed : CF is Master ATA
JP3 - 1-2 : Normal operation (otherwise CMOS would be cleared!)
JP4/5 - 1-2 : Power jack (otherwise the RB would not start, no PoE attached)
JP6 - 1-2 : MiniUPS deselect
As far as I understand the only jumper in question is JP2, and it is closed (tried it open as well - no luck). Agree?
Have not been able to try 2.5" IDE, have no 44-pin flat cable.
But is it very likely that this would work as CF doesn’t?
Hi Bomber67! Where you see JP6 jumper on RB230rev3. ?! This jumper present only on first rev. RB200. What actually RB you have?!
RouterBIOS-200 v1.3.7 MikroTik ™ 2003-2005
Memory size: 128 MB
d - boot delay
k - boot key
s - serial console
l - debug level
o - boot device
b - beep on boot
v - vga to serial
t - ata translation
p - memory settings
m - memory test
u - cpu mode
f - pci back-off
i - board info
x - exit setup
I haven’t checked whether JP6 is there.
Actually, as a response to normis’ last post I was iterating through all the jumpers mentioned in the user manual to prove that no jumper except JP2 can possibly be the reason for my problem.
For several of the jumpers a wrong position would simply keep my board from booting at all, that’s my point.
aaa: Have you (bad) experience with this board?
Maybe some hardware malfunction can be reason your problem. Have you possibility swap your RB200 with otherone?About experience I consider RB200 like one of the most successful project. In few places it work fine 2-3 years and not need upgade to something else.
I have to agree. The RB230 is one of my favorite routerboards due to its versitility and reliability. We have had four in operation for more than three years now. Only had to replace one due to lightning damage. And yes, we boot to CF on all of them.
