[Help] RB912UAG-5HnD is no longer driven.
Hello, all
I am using a RB912UAG-5HnD, but they have already started where it was re-started by applying the ROS6.18.
  • I was pressing the reset button, but is not reset.
  • Netinstall also I tried, but I will stop with the message “partitioning and formating harddrive”.
How Will I say this was the brick?
Is there anything I can do to the other me?
Best regards.
It was confirmed that Netinstall to operate normally by seems to have a behavior not good ThinkVantage Access Connections of ThinkPad that has been used apparently, to fix the IP address in the OS configuration.
I’d appreciate it if accustomed to help someone.
