I have this up in the routeros community support general. I think wireless is were it should go.
routeros v 3.9 is on the 192
i have a rd 192 i want to use for a home network. I put this on it the same as a rd 450
this works great
#| ether1 is renamed ether1-gateway, rest of interfaces are switched
#| IP address 192.168.80.1/24 is on switch
#| DHCP client is on ether1-gateway
#| DHCP server is on switch, with address pool 192.168.80.10-192.168.80.254
#| masquerade on ether1-gateway
I want to use the wireless card i put is on this. This is like the configuration on rb 751-2n
#| ether1 is renamed to ether1-gateway
#| DHCP client and masquerade is set on ether1-gateway
#| ether2 is renamed to ether2-master-local and configured as switch master port for ether3-ether5
#| ether2-master-local and wlan1 are bridged
#| wireless is set as access point in 2412MHz using both chains and extension channel enabled.
#| IP address 192.168.88.1/24 and DHCP server is set on bridge interface
#| DHCP servers address pool is 192.168.88.10-192.168.88.254
the switch will not work
help please
