Help routing problem
I have been trying to setup a RB433 (V5.11) with 192.168.1.17 (Gateway to internet 192.168.1.1) on Wlan1 and 192.168.2.1 on Bridge1. No matter what I have tried I cannot get a connection from 1 networkto the other.
What have I done wrong or what is missing?
ip> address print
ADDRESS NETWORK INTERFACE
0 192.168.1.17/24 192.168.1.0 wlan1
1 192.168.2.1/24 192.168.2.0 bridge1
/ip> route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 wlan1 1
1 ADC 192.168.1.0/24 192.168.1.17 wlan1 0
2 ADC 192.168.2.0/24 192.168.2.1 bridge1 0
ip firewall> nat print
0 chain=srcnat action=masquerade out-interface=wlan1
Richard
bit of a noob myself so this may not work try adding /ip route add gateway=192.168.1.1
Your default route has the wlan interface on it, this only works for ppp type connections.
You need to specify the next hop IP address instead.
Nick.
Pardon my ignorance but how do I set the next hop?
Richard
If you mean you can’t access devices on the bridge from devices on wlan1, that is correct. Unless you route that from the wlan1 gateway router, you can’t.
If you mean you can’t access wlan1 devices from the bridge, then you have a problem. That would probably be solved by columf’s suggestion.
I have tried columf's suggestion. config is:-
/ip address> print
/ip route> print
0 A S 0.0.0.0/0 192.168.1.1 1
1 S 0.0.0.0/0 wlan1 1
2 ADC 192.168.1.0/24 192.168.1.17 wlan1 0
3 ADC 192.168.2.0/24 192.168.2.1 bridge1 0
ip firewall nat> print
I cannot ping Wlan1 from Bridge 1
Any thoughts?
Richard
Can you ping 192.168.1.1 from the bridge?
Can you ping from a wlan1 device to another wlan1 device?
