Hello to all!
I need to apply same mangle rule on group of interfaces (N interfaces).
Example:
add action=mark-packet chain=prerouting comment=POP3 disabled=no dst-port=\
1025-65535 in-interface=ether3 new-packet-mark=pop3_in passthrough=no \
protocol=tcp src-port=110
add action=mark-packet chain=postrouting comment="" disabled=no dst-port=110 \
new-packet-mark=pop3_out out-interface=ether3 passthrough=no protocol=tcp \
src-port=1025-65535
I need to replicate this rule even in ether4 and ether 6,.
Consider that I have many of this rule and it’s very expensive to replicate for N interfaces.
RouterOS, not accept mangle rule whit “in-interface=ether3,ether4,ether6”
A solution would be to preventive mark all packets to/from this N interfaces, like
“group_in/group_out” and apply the rules on all interfaces, but only on “group packets”?
Can you help me?
it’s not as expensive as you think - just replicate =)
I have to replicate many rules, over 50!
50 rules
3 interfaces
50 x 3 = 150 rules…
well, you may do it in two steps:
mark packets from ether3, ether4, ether6 - three rules
mark packets having packet-mark from step 1 based on ports etc
only three additional rules =)
…3 + 3 additional rules (from/to)
This agree whit my idea of “preventive mark packets” from/to this interfaces.
No alternative solution exist?
TNX!
well, ‘alternative solutions’… when you forcibly set in-interface or out-interface, then when the list of interfaces changes, you need to change 50s of rules. and with my solution, you need only change 3+3 rules
so I don’t see much sense in other solutions
Chupaka:
Your solution is my solution
But, I think that is possible a more optimized solution…
oh, yeah, just re-read your first post =)
why do you think it’s not optimized? it’s easy to use, easy to modify… is CPU load too high?
create jump rules for each interface to the same chain. Then use only a single set of mangle rules in that chain. This is what chains are for, so you can reuse your rules.
Ok, I understand, but I m a bit confused…
Can you show a little example?
Chupaka
August 16, 2008, 10:56pm
11
/ip firewall mangle
add action=jump chain=prerouting comment="" disabled=no in-interface=lollipop jump-target=kaboom-in
add action=mark-packet chain=kaboom-in comment="" disabled=no new-packet-mark=bzzz passthrough=yes protocol=tcp
A possible start (for me ) solution:
/ip firewall mangle
add action=jump chain=prerouting comment="" disabled=no in-interface=ether2 jump-target=QoS-in
add action=jump chain=postrouting comment="" disabled=no jump-target=QoS-out out-interface=ether2
add action=jump chain=prerouting comment="" disabled=no in-interface=bridge1 jump-target=QoS-in
add action=jump chain=postrouting comment="" disabled=no jump-target=QoS-out out-interface=bridge1
add action=mark-packet chain=QoS-in comment=ICMP disabled=no new-packet-mark=icmp_in passthrough=no protocol=icmp
add action=mark-packet chain=QoS-out comment="" disabled=no new-packet-mark=icmp_out passthrough=no protocol=icmp
add action=mark-packet chain=QoS-in comment=DNS disabled=no new-packet-mark=dns_in passthrough=no protocol=udp src-port=53
add action=mark-packet chain=QoS-out comment="" disabled=no dst-port=53 new-packet-mark=dns_out passthrough=no protocol=udp
add action=mark-packet chain=QoS-in comment=WinBOX disabled=no new-packet-mark=winbox_in passthrough=no protocol=tcp src-port=8291
add action=mark-packet chain=QoS-out comment="" disabled=no dst-port=8291 new-packet-mark=winbox_out passthrough=no protocol=tcp
add action=mark-packet chain=QoS-in comment=SSH disabled=no new-packet-mark=ssh_in passthrough=no protocol=tcp src-port=22
add action=mark-packet chain=QoS-out comment="" disabled=no dst-port=22 new-packet-mark=ssh_out passthrough=no protocol=tcp
add action=mark-packet chain=QoS-in comment=PPtP disabled=no new-packet-mark=gre_in passthrough=no protocol=gre
add action=mark-packet chain=QoS-out comment="" disabled=no new-packet-mark=gre_out passthrough=no protocol=gre
add action=mark-packet chain=QoS-in comment=HTTP_Video disabled=no layer7-protocol=http-video new-packet-mark=http-video_in \
add action=mark-packet chain=QoS-out comment="" disabled=no layer7-protocol=http-video new-packet-mark=http-video_out passthrough=no \
protocol=tcp
[cut]
In this simple rule set:
substitute “prerouting” chain whit “QoS-in” chain
substitute “postrouting” chain whit “QoS-out” chain
not specified in/out interface
