Help setting dual wan with failover
Hi, can help me somebody step by step to set my router rb850gx2 in dual wan mode with failover.
twan 1 rcs 5.2.xxx.xxx gateway 5.2.xxx.xxx
wan 2 upc 192.168.1.5 gateway 192.168.1.1
lan 192.168.5.1 ports 3, 4 ,5 in bridge mode
dhcp server on lan, start on 192.168.5.200 end to 192.168.5.254
wan 1 will be default connection,
Is my first router from mikrotik, im beginer,
I hope this helps you.
See the printscreens a made on my website.
http://www.wirelessinfo.be/index.php/mikrotik/pages/overflow
it works, thanks a lot
Are both wans the same speed?
Do you really want one active and the other as a passive failover? Better have both active.
Easiest way is to put the failover route with a 2 distance so in case the main one stops working the 2nd kicks in. Check them with ping in the route configuration.
Sent from my Nexus 4 using Tapatalk
Think. What happens when the first gateway is accessible but does not have access to Internet?
True. Using scripts you can change routes distance. Pinging an internet destination.
First, he needs to realize what he wants to achieve. Including details that the one you mention.
on first conection i have 90mbps and on second conection i have only 20mbps. i want to use second conection only when wan 1 is down.
