I’m trying to configure Capsman with CRS switch configured as a router and a wAP ac but it’s failing to bring up either of the wlan on the cAP. Can someone have a quick glance over the relevant parts of my config. I’m sure i’m missing something very simple.
add band=2ghz-onlyn extension-channel=Ce frequency=2412 name=channel1 width=40
add band=5ghz-a/n/ac extension-channel=Ceee frequency=5210 name=channel42 width=80
Delete the width on both interfaces or try changing them to 20
That has not made any difference. I’ve now added a bridge on the wAP and added it as bridge in CAP settings. The Caps Manager and the CAP are not talking, although the CAP says it’s being controlled by Caps Manager it doesn’t appear to be getting any settings from it. My wlan interfaces are disabled on the cAP. Here’s my exports now
Ok, got it sorted, the cm2 wireless package was not installed even though I had the Capsman options. Now to configure and add my second wAP to see how my roaming goes
I have these configured and working, but both using the same config which means they’re both on the same channel. As they are in pretty close proximity to each other should I be forcing them to different channels or setting them to auto?
I have done this and it now assigns channels 3 and 7 to the 2ghz radios but the radio on channel 7 drops out every few minutes continuously.
On 5Ghz I can only see one radio working on channel 36, the other CAP says it’s on channel 149 but my analyser doesn’t see it, not sure if it’s a problem with my analyser yet.
