Help setting up IPv6
Hi, I’ve just installed RouterOS x86 on my mini PC and most functions are working, but I can’t figure out how to get IPv6 working on my VLANs. My ISP delegates a /56 prefix via DHCPv6 which I have applied, but I can’t work out how to get my devices to receive their own public-facing IPv6 addresses. Any advice is greatly appreciated. Please find attached my *.rsc file.
setup.rsc (3.06 KB)
for the start you need to assign /64 (with advertise enabled) to your VLAN interfaces and enable ipv6/nd for these VLANs, and then your LAN devices should receive ipv6 inside the VLANs
I did that, just doing it for my main vlan with ID 10 for now, but if I open my neighbor list it does seem like my PC has tried to assign itself an address but the MAC address is zeroed out, and the status says failed:
have you tried with another PC/laptop/mobile device?
Sure have, can’t figure this out for the life of me.
can you show your ipv6 firewall config?
It’s blank currently, I’ve not configured anything on the IPv6 firewall.
