Help setting up mikrotik RB951ui-2hnd as access point for another mikrotik RB951ui-2hnd
Hi guys, i am in urgent need of help setting up my mikrotik RB951ui-2hnd as access point for another mikrotik RB951ui-2hnd. i currently have my hotspot service setup on the first mikrotik and i wish to use the second mikrotik RB951ui-2hnd as an access point to the hotspot on the first mikrotik. i would really appreciate your help on this. Thank you
1.Connect your Internet cable to port 1, and LAN computers to ports 2-­‐52.Set LAN computer IP configuration to automatic(DHCP)3.Wireless AP mode is enabled by default, you can connect to the SSID “MikroTik”. Log into your router from your web browser byopening 192.168.88.1 in the address bar4.The Ether5 port suports PoE output, with auto detection feature. This means you can connect Laptops and other non-­‐PoE devices without damaging them. The PoE on Ether5 outputs approximately 2V below input voltage, and supports up to 0.58A (So provided 24V PSU will provide 22V/0.58A output to the Ether5 PoE port)5.Please note that for some units a wireless password is configured.
Let me know If this is helpful
