Help setting up new router - RB4011
I purchased the RB4011 and I need some help setting it up. One of the reasons I purchased it is because reviews said it was “plug and play” using the default configuration. Well, not exactly. The one change I made was to change the IP to 192.168.100.1 (which I have to have). The router looks around the LAN fine, but I cannot go to the internet. I noticed there is a firewall up for IPv4 that may be blocking internet access? Can anyone give me the commands that will allow the router to work? TIA!!
If you changed the IP for your LAN bridge you should change dhcp pool and dhcp-server network as well.
How did you make the change, quickset?
Do you mean the wan IP is fixed at that IP??
Not sure what you were referring to.
