I have a router mikrotik RB1100. I have the following port settings:
-------group1(switch1 Atheros 8316)-------
ether1=WAN connection
ether2=PPPoEserver
ether3=(master-port ether2) client PPPoE
ether4=(master-port ether2) client PPPoE
ether5=(master-port ether2) client PPPoE
I can not communicate group1 with group2. That is, I want group2 ports are also clients of the PPPoEserver (ether2), but I can not. I have tried to bridge the ether2 and ether6 (and ether7-10 as slaves of the ether6) does not work. How I can do?
i want the following port settings:
ether2=PPPoE server
PPPoEserver is configured on ether2 and the ports ether3, ether4 and ether5 are slaves (clients of the server) of ports ether2. And so I can use the ports ether2-ether5 as clients of the PPPoEserver.
With that configuration of the 5 ports, all right. But the problem is that I need more ports for more connection and need to use ports ether6-ether10 and I can not how.
That is, I mean:
if I physically connect a cable from port ether5 to port ether6,
everything works. But I want to do it internally and not waste the two ports(ether5 and ether6)
for you to understand me.
Ether2 (PORT-MASTET. )-------------> Server configured here here I can connect any antenna wimax (access points)
| __Ether3 (Slave )-------------> here I can connect any antenna wimax (access points)
| __Ether4 (Slave )-------------> here I can connect any antenna wimax (access points)
| __Ether5 (Slave )-------------> here I can connect any antenna wimax (access points)
And now I need to connect more antennas and I have to put them because if I connect the ports that I have free (ether6-ether10) does not work. And I know how to communicate those ports (ether6-ether10) with ether2.
i want this:
|…|HOW I CAN CONNECT THE SWITCHS?¿?¿?
|Ether6 (Slave )-------------> how I can connect any antenna here?__|
|__Ether7 (Slave )-------------> how I can connect any antenna here?
|__Ether8 (Slave )-------------> how I can connect any antenna here?
|__Ether9 (Slave )-------------> how I can connect any antenna here?
|__Ether10(Slave )-------------> how I can connect any antenna here?
there are two physical switch groups, so either you create one more PPPoE server (what’s problem?!? it makes no difference at all!), or you get 5 cm patchcord to connect switchgroups and loose two ports
