Help setup my D54G-5HacD2HnD and RBD52G-5HacD2Hnd
So my D53G is set up as a LTE AP Dual(in quick set)then it goes to a CSS326-24G-2S+,from there it goes to the RBD52G(hAP ac2).
How should I setup the hap ac2 so I can connect to it with phones wirelessly and via PC(ethernet).
Router export
# dec/15/2021 12:08:08 by RouterOS 7.0.2
# software id = FDRP-BHZ1
# model = D53G-5HacD2HnD
# serial number = D7B00EA5AA0A
add admin-mac=2C:C8:1B:56:C0:41 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=no_country_set \
    disabled=no distance=indoors frequency=auto frequency-mode=superchannel installation=outdoor mode=\
    ap-bridge ssid=CROMITEH-2GHz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX country=no_country_set \
    ap-bridge ssid=CROMITEH-5Ghz wireless-protocol=802.11
/interface lte
set [ find ] allow-roaming=no name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=\
    MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/interface bridge host
add bridge=bridge interface=wlan1 mac-address=0C:B6:D2:F3:E9:B6
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=lte1 list=WAN
/interface lte settings
set external-antenna=both
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
/ip dhcp-client
add disabled=no interface=ether1
add address=0.0.0.0/24 gateway=0.0.0.0 netmask=24
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=\
    127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=\
    !dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
    out-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 \
    protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=\
    in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=\
    icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=\
    in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" \
/system clock
set time-zone-name=Europe/Zagreb
/system routerboard settings
set cpu-frequency=auto
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
hAp ac2 export as of now
# jan/02/1970 01:17:43 by RouterOS 6.49
# software id = XZGK-R3MU
# model = RBD52G-5HacD2HnD
# serial number = E5780E2910E2
add admin-mac=2C:C8:1B:75:73:99 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=croatia disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=Mileni-2GHz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    indoor mode=ap-bridge ssid=Mileni-5GHz wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add address=192.168.89.1/24 comment=defconf interface=bridge network=\
    192.168.89.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.89.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
    192.168.89.1 netmask=24
/ip dns static
add address=192.168.89.1 comment=defconf name=router.lan
    invalid
add action=drop chain=input comment="defconf: drop all
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    "defconf: accept established,related, untracked" co
add action=drop chain=forward comment="defconf: drop in
    invalid
    connection-nat-state=!dstnat connection-state=new i
    out,none out-interface-list=WAN
/tool mac-server
