[Help]Some question about RB962UiGS-5HacT2HnT upgrade to RB5009UG+S+IN
I have a RB962UiGS-5HacT2HnT(RouterOS 6.49.6) Router that is using。I want to upgrade to RB5009UG+S+IN(Router OS 7)。Now,I made a backup of RB962UiGS-5HacT2HnT router’s settings。
Then I have two questions。
1.Whether the backup settings can be used normally after restoration to RB5009UG+S+IN?
2.If it doesn’t work what needs to be done? Should Set from beginning?
