Help SSH remote access
I have set up SSH access on my MikrotikCHR7 router and I can’t access it remotely via putty or the terminal.
My SSH server is on 192.168.122.59/24.
My PC or I test in 192.168.1.33/24.
Do you have anything to enlighten me on the subject, because I’ve been going in circles for 7 hours now.
Thanks in advance.
The problem is either the configuration on your CHR MT router, or your home MT router.
https://help.mikrotik.com/docs/display/ROS/SSH
https://www.youtube.com/results?search_query=ssh+mikrotik
Can you access your CHR router with Winbox? With a console? What do they show?
For example, does it have an IP address? Does it have a route configured?
Does your PC 192.168.1.33/24 have a route to 192.168.122.0/24? Does 192.168.122.0/24 have a route to 192.168.1.0/24?
How remotely are you trying to access it? Other side of the country for example.
SSH between two MT routers is easy and requires no certificate even, but I only use it as a backup to wireguard.
[user=anav]
I’m thinking this thread should just be deleted.. No response from OP since opening the thread.. Oh well..
kevinds, next time you fly to Nova Scotia, give me a shout, I think I owe you at least 3 beers :slight_smile:
