HELP SXT LTE6 Kit Automatic SIM Switching
I can’t understand why the script for connecting a SIM card does not work. I took the official script Dual SIM Application as a basis and replaced down up with a.b, I don’t have up and down in the settings.
Help please people are kind
# Setup and read current values
:global simSlot [/system routerboard modem get sim-slot]
:global timeoutLTE 60
:global timeoutConnect 60
# Wait for LTE to initialize for maximum "timeoutLTE" seconds
:local i 0
:local isLTEinit false
:while ($i<$timeoutLTE) do={
    :foreach n in=[/interface lte find] do={:set $isLTEinit true}
    :if ($isLTEinit=true) do={
        :set $i $timeoutLTE
    :set $i ($i+1)
    :delay 1s
# Check if LTE is initialized, or try power-reset the modem
    # Wait for LTE interface to connect to mobile network for maximum "timeoutConnet" seconds
    :local isConnected false
    :set $i 0
    :while ($i<$timeoutConnect) do={
        :if ([/interface lte get [find name="lte1"] running]=true) do={
            :set $isConnected true
            :set $i $timeoutConnect
        :set $i ($i+1)
        :delay 1s
    # Check if LTE is connected
    if ($isConnected=false) do={
	# Check which SIM slot is used
        :if ($simSlot="a") do={
            # If "down" slot, switch to up
	    :log info message="LTE down, switching slot to UP"
	    /system routerboard modem set sim-slot=b
        :if ($simSlot="b") do={
            # If "up" slot, switch to down
	    :log info message="LTE down, switching slot to DOWN"
	    /system routerboard modem set sim-slot=a
        } else={
            # Else "running"
            :if ($isConnected=true) do={
                :log info message="LTE UP"
    } else={
        :log info message="LTE interface did not connect to network, wait for next scheduler"
} else={
    :log info message="LTE modem did not appear, trying power-reset"
    /system routerboard usb power-reset duration=5s
This script do many stuff and the latest RouterOS have litle differ syntax. Means this script should be updated… .
What you want do in final situation ?
I not like this script becase you can not have internet and the lte1 can be still Running, then it not switch to other sim card.
Check my KB at signature.
