Help to Choose a Model
Hello All, We are new with MikroTik RouterBoard Hardware Device so need some help please. We are looking below functionality in a RouterBoard HW models so if anyone can suggest witch model will better for us. Please note, we are specially looking hardware base solution.
  1. Manage minimum of 10Mb Internet bandwidth.
  2. Support VPN protocols for outgoing connections for local users.
  3. Support minimum of 250GB HDD in local or external (USB) for Cache Proxy Storage.
  4. Support NAT and Firewall to support as Internet Gateway for Local Users.
Number 2 is very much requirement. Any help is appreciating.
Thank you and see you all again.
Numbers of ETH and SFP ports?
Wifi?
No reply…
Very Sorry for the delay response and not mention my connectivity requirement,
Functionality Requirement,
  1. Manage minimum of 10Mbps Internet bandwidth.
Connectivity Requirement,
  1. Minimum 6 Ethernet Port (rack mountable)
  2. Minimum 100Mb LAN or Wan (GB will also do)
  3. No WiFi require.
  4. No SFP require.
  5. USB Port for External USB
Please let us know if any other information need.
And many thanks for the reply.
This is the routerboard that will do the job :
RB2011UiAS-RM
It is rack mountable, it has 5 gigabit ports and 5 100mbit ports, it supports vpn, has usb for cache storage, it will do nat and basic firewall for a lot more than 10mbit/s. As a bonus you get sfp.
Thank you for the suggestion.
Just checked the Model detail and have an interest on License Level 6 Models.
Any suggest models from L6 for our need?
Also another Question, what kind of Hard disk the Model Support.
Thank you all for your time.
L6?
RB1100AHx2
About Hard Disk: no one single model has internal hard disk!
1100AHx2 do not have USB for external disk. Only microSD slot.
Why do you need level 6?
http://routerboard.com/RB2011UiAS-RM have USB and LEVEL5 ($119)
If you need LEVEL6 and USB there is only http://routerboard.com/CCR1009-8G-1S ($425)
Good Day.
Many many thank you to all. May need L6 or may not, who know what will the requirement in the future. So better go for L6. And don’t like Limits.
Need to Clarify, We are actually not looking for Local VPN Server, Actually looking for Local Clients or Users can connect to external VPN Servers using VPN Client. Hope Those Models you peoples mention support the VPN Client Protocols through NAT. (PPTP, L2TP, IPSEC, VPNoverHTTPS tunnel, IPSec etc).
And Hope any Ordinary Portable MicroUSB HDD (for Example - WD,MicroUSB, 250GB HDD/SSD) is supported.
Around 400 Users and 200 are Heavy Internet Browsing Users.
Just need one more help. Which one is better on our need and future growth, both models are with-in our range,
  1. RB2011UiAS-RM
  2. CCR1009-8G-1S-1S+
Thank you again for the help.
If you want to be future oriented and maybe switch to higher speeds some day, go with the CCR option. The 2011 is not capable of real world NAT beyound 200Mbps.
Thanks. Any suggestion from the Gurus?
If price is not a problem - I go to the CCR
Many Thanks for the Help.
Any here from Singapore? looking for a Direct Sells Shop Local in Singapore.
there are several companies in Singapore that sell our products: http://www.mikrotik.com/buy/asia/singapore
Thank you very much Mr Normis.
Forget to Ask one more question, Very sorry about that.
Is there any renewal/subscribe for every yeas Or it is just a OTA(one time cost) box?
We are actually Having 2(for redundancy) of CCR Model and mainly for Bandwidth Control and Internet Gateway for Local Users.
Thank you again.
for RouterBOARD devices - it is one time cost.
Many thank you to Everyone for the HELP.
Hope CCR1009-8G-1S-1S+ model is now available in SG market.
Thanks Again.
