i sourced some info from the net and configured the hotspot...here
see bellow my config
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.1 (c) 1999-2013 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambigous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
jan/02/1970 00:00:08 system,error,critical router was rebooted without proper shut
down
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > ip address print
ADDRESS NETWORK INTERFACE
0 ;;; default configuration
192.168.88.1/24 192.168.88.0 ether1
[admin@MikroTik] > ip address remove 0
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > ip address add address=41.139.192.50/30
interface: ether1
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > ip route add gateway=41.139.192.49
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 41.139.192.53 1
1 ADC 41.139.192.52/30 41.139.192.54 ether1 0
[admin@MikroTik] >
[admin@MikroTik] > ip hotspot pr
profile print
[admin@MikroTik] > ip hotspot print
Flags: X - disabled, I - invalid, S - HTTPS
NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
[admin@MikroTik] >
[admin@MikroTik] > ip hotspot set
set setup
[admin@MikroTik] > ip hotspot setup
Select interface to run HotSpot on
hotspot interface: ether3
Set HotSpot address for interface
local address of network: 192.168.20.1/24
masquerade network: yes
Set pool for HotSpot addresses
address pool of network: 192.168.20.25-192.168.20.254
Select hotspot SSL certificate
select certificate: none
Select SMTP server
ip address of smtp server: 0.0.0.0
Setup DNS configuration
dns servers: 41.203.208.30,41.203.208.38
DNS name of local hotspot server
dns name:
Create local hotspot user
name of local hotspot user: admin
password for the user: ****
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
0 41.139.192.50/30 41.139.192.48 ether1
1 ;;; hotspot network
192.168.20.1/24 192.168.20.0 ether3
profile print
0 hotspot1 ether3 hs-pool-8 hsprof1 5m
[admin@MikroTik] /ip hotspot> profile
[admin@MikroTik] /ip hotspot profile> print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot
rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0
login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no
use-radius=no
1 name="hsprof1" hotspot-address=192.168.20.1 dns-name=""
html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
[admin@MikroTik] /ip hotspot profile> cd /..
bad command name cd (line 1 column 1)
[admin@MikroTik] /ip hotspot profile> ..
[admin@MikroTik] /ip hotspot> ..
[admin@MikroTik] /ip> ..
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > ip hotspot user print
Flags: X - disabled, D - dynamic
SERVER NAME ADDRESS PROFILE UPTIME
0 admin default 0s
[admin@MikroTik] > ip hotspot profile
[admin@MikroTik] /ip hotspot profile> set 1 use-radius=yes
Flags: * - default
use-radius=no
split-user-domain=no use-radius=yes radius-accounting=yes
radius-interim-update=received nas-port-type=wireless-802.11
radius-default-domain="" radius-location-id="" radius-location-name=""
radius-mac-format=XX:XX:XX:XX:XX:XX
[admin@MikroTik] /ip hotspot> walled-garden
[admin@MikroTik] /ip hotspot walled-garden> print
SERVER METHOD DST-HOST DST-PORT PATH ACTION HITS
[admin@MikroTik] /ip hotspot walled-garden> ..
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > tool user-manager customer add login=cyber password=elanor
[admin@MikroTik] > tool user-manager router
[admin@MikroTik] /tool user-manager router> user
bad command name user (line 1 column 1)
.. -- go up to user-manager
add -- Create a new item
comment -- Set comment for items
disable -- Disable items
edit --
enable -- Enable items
export -- Print or save an export script that can be used to restore configuration
find -- Find items by value
get -- Gets value of item's property
monitor --
print -- Print values of item properties
remove -- Remove item
reset-counters --
set -- Change item properties
[admin@MikroTik] /tool user-manager router> ..
[admin@MikroTik] /tool user-manager> user
[admin@MikroTik] /tool user-manager user> print
Flags: X - disabled, A - active, I - incomplete
[admin@MikroTik] /tool user-manager user> ..
[admin@MikroTik] /tool user-manager> customer
[admin@MikroTik] /tool user-manager customer> print
Flags: X - disabled
0 login="admin" password="" backup-allowed=yes time-zone=-00:00
permissions=owner signup-allowed=no paypal-allowed=no
paypal-secure-response=no paypal-accept-pending=no
1 login="cyber" password="elanor" backup-allowed=yes time-zone=-00:00
[admin@MikroTik] /tool user-manager customer> ..
[admin@MikroTik] /tool user-manager> ..
[admin@MikroTik] /tool> ..
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] /tool user-manager router> print
Flags: X - disabled
[admin@MikroTik] /tool user-manager router> add ip-address=127.0.0.1 shared-secret=
elanor
customer: cyber
[admin@MikroTik] /tool user-manager> ...
bad command name . (line 1 column 3)
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > radius add service=hotspot address=127.0.0.1 secret=elanor
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] > ip hotspot profile print
Flags: * - default
use-radius=no
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
[admin@MikroTik] >
nw, m having an issue with configuring a another dhcp server to provide ips to the cyber cafe machines
