parent definition for a queue using PHP api is not working for MikroTik RouterOS 6.0rc11
i am currently using Denis Basta’s PHP api class
and my add queue code is
$ARRAY = $this->api_model->comm("/queue/simple/add", array(
"name" => $somedata['name'],
"parent"=>$parent_name,
"target-addresses" => $ips,
"max-limit"=>$somedata['rx_max_limit']."/".$somedata['tx_max_limit'],
which is not working for MikroTik RouterOS 6.0rc11(firmware version 3.04)
but worked for older version…
my problem is the parent parameter in above code does not make any response
the parameter “parent” in above code does not made any sense and change to newer version mtik router
