I have an ax3 with 3 VLAN setup (home, iot and guest), and an ax2 as CAP/switch.
I want to setup mDNS to work between VLANs, but I am a bit confused about firewall rules.
I have enabled mDNS:
set mdns-repeat-ifaces=vlan-home,vlan-iot,vlan-guest
My 3 VLANs are in a list named VLANS. I have a rule to deny traffic between the VLANS.
add action=reject chain=forward comment="VLANS: isolated from each other" \
in-interface-list=VLANS out-interface-list=VLANS reject-with=\
icmp-admin-prohibited
Maybe I need to think about this and change to rules that only allow iot and guest access to WAN?
So, I have created a firewall rule like this, but not sure if it is the correct way to allow mDNS to work.
add action=accept chain=input comment=allow-mDNS dst-address=224.0.0.251 \
dst-port=5353 in-interface-list=VLANS protocol=udp
The rule is placed before the “drop all not coming from LAN”.
Here is the complete export:
# 2026-05-06 19:32:36 by RouterOS 7.22.2
# software id = WAZD-3LKR
# model = C53UiG+5HPaxD2HPaxD
# serial number =
add admin-mac=F4:1E:57:9E:1B:29 auto-mac=no comment=defconf frame-types=\
admit-only-vlan-tagged igmp-snooping=yes name=bridge vlan-filtering=yes
/interface eoip
add local-address=172.17.0.1 mac-address=FE:42:C5:9B:26:02 mtu=1500 name=\
eoip-iptv-al remote-address=172.17.0.2 tunnel-id=0
add local-address=172.17.0.5 mac-address=FE:D9:9C:6F:15:2F mtu=1500 name=\
eoip-iptv-cr remote-address=172.17.0.6 tunnel-id=1
/interface wireguard
add comment=back-to-home-vpn listen-port=6888 mtu=1420 name=back-to-home-vpn
add listen-port=54321 mtu=1420 name=wg-sts-iptv-al
add listen-port=54322 mtu=1420 name=wg-sts-iptv-cr
/interface vlan
add arp=reply-only interface=bridge name=vlan-guest vlan-id=30
add interface=bridge name=vlan-home vlan-id=10
add interface=bridge name=vlan-iot vlan-id=20
add interface=ether1 name=vlan2-iptv vlan-id=2
add interface=ether1 name=vlan3-telefono vlan-id=3
add interface=ether1 name=vlan6-internet vlan-id=6
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan6-internet name=internet \
user=adslppp@telefonicanetpa
/interface ethernet switch
set 0 cpu-flow-control=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=vlans-iptv-voip name=VLANs2&3
add name=VLANS
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412 name=2,4Ghz-ch01 width=20mhz
add band=2ghz-ax disabled=no frequency=2462 name=2,4Ghz-ch11 width=20mhz
add band=5ghz-ax disabled=no frequency=5180 name=5Ghz-ch36 width=20/40/80mhz
add band=5ghz-ax disabled=no frequency=5500 name=5Ghz-ch100 width=20/40/80mhz
/interface wifi datapath
add bridge=bridge disabled=no name=wifi-home vlan-id=10
add bridge=bridge disabled=no name=wifi-iot vlan-id=20
add bridge=bridge client-isolation=yes disabled=no name=wifi-guest vlan-id=30
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes \
name=home wps=disable
name=iot wps=disable
name=guest wps=disable
/interface wifi configuration
add channel=5Ghz-ch100 country=Spain datapath=wifi-home disabled=no \
dtim-period=3 mode=ap name=5Ghz-local security=home ssid=Mikrotik
add channel=2,4Ghz-ch01 country=Spain datapath=wifi-home disabled=no \
dtim-period=3 mode=ap name=2,4Ghz-cap security=home ssid=Mikrotik \
tx-power=15
add channel=5Ghz-ch36 country=Spain datapath=wifi-home disabled=no \
dtim-period=3 mode=ap name=5Ghz-cap security=home ssid=Mikrotik
add country=Spain datapath=wifi-iot disabled=no mode=ap name=iot security=iot \
ssid=Mikrotik_IoT
add country=Spain datapath=wifi-guest disabled=no dtim-period=3 mode=ap name=\
guest security=guest ssid=Mikrotik_Guests
/interface wifi
set [ find default-name=wifi1 ] configuration=5Ghz-local configuration.mode=\
ap datapath=wifi-home disabled=no name=wifi-5ghz
add configuration=guest configuration.mode=ap disabled=no mac-address=\
F6:1E:57:9E:1B:2D master-interface=wifi-5ghz name=wifi-5ghz-invitados
add configuration=iot configuration.mode=ap disabled=no mac-address=\
F6:1E:57:9E:1B:2E master-interface=wifi-5ghz name=wifi-5ghz-iot
/ip dhcp-server option
add code=240 name=opch-imagenio value="':::::239.0.2.29:22222'"
add name=pool-home ranges=192.168.10.20-192.168.10.239
add name=pool-iptv ranges=192.168.10.241-192.168.10.254
add name=pool-iot ranges=192.168.20.2-192.168.20.254
add name=pool-guest ranges=192.168.30.2-192.168.30.254
add address-pool=pool-home interface=vlan-home name=dhcp-home
add address-pool=pool-iot interface=vlan-iot lease-time=1d name=dhcp-iot
add add-arp=yes address-pool=pool-guest interface=vlan-guest name=dhcp-guest
/routing rip instance
add afi=ip disabled=no name=rip
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
source="\r\
\n :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
p\" && disabled=no)] do={\r\
\n /interface/wifi wps-push-button \$iface;}\r\
\n "
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface wifi
set [ find default-name=wifi2 ] configuration=2,4Ghz-local \
configuration.mode=ap datapath=wifi-home disabled=no name=wifi-2,4ghz
F6:1E:57:9E:1B:2F master-interface=wifi-2,4ghz name=wifi-2,4ghz-invitados
F6:1E:57:9E:1B:30 master-interface=wifi-2,4ghz name=wifi-2,4ghz-iot
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
admit-only-untagged-and-priority-tagged interface=ether4 pvid=10
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether5
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=eoip-iptv-al pvid=10
interface=eoip-iptv-cr pvid=10
/interface bridge vlan
add bridge=bridge comment=home tagged=bridge,ether5 vlan-ids=10
add bridge=bridge comment=iot tagged=bridge,ether5 vlan-ids=20
add bridge=bridge comment=guest tagged=bridge,ether5 vlan-ids=30
add comment=defconf interface=internet list=WAN
add interface=vlan2-iptv list=VLANs2&3
add interface=vlan3-telefono list=VLANs2&3
add interface=vlan-home list=LAN
add interface=vlan-home list=VLANS
add interface=vlan-iot list=VLANS
add interface=vlan-guest list=VLANS
/interface wifi capsman
set enabled=yes interfaces=vlan-home package-path="" \
require-peer-certificate=no upgrade-policy=suggest-same-version
add channel=2,4Ghz-ch11 country=Spain datapath=*4 disabled=no dtim-period=3 \
mode=ap name=2,4Ghz-local security=home ssid=Mikrotik tx-power=15
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=2,4Ghz-cap \
name-format=cap-2ghz radio-mac=78:9A:18:FE:B0:3F slave-configurations=\
guest,iot
add action=create-dynamic-enabled disabled=no master-configuration=5Ghz-cap \
name-format=cap-5ghz radio-mac=78:9A:18:FE:B0:3E slave-configurations=\
guest,iot
/interface wireguard peers
add allowed-address=172.17.0.2/32 comment=gorron-iptv endpoint-address=\
xxxxxx.sn.mynetname.net endpoint-port=54321 interface=wg-sts-iptv-al \
name=peer1 public-key=""
add allowed-address=172.17.0.6/32 comment=gorron-iptv endpoint-address=\
xxxxxx.sn.mynetname.net endpoint-port=54322 interface=wg-sts-iptv-cr \
name=peer5 public-key=""
add address=192.168.10.1/24 interface=vlan-home network=192.168.10.0
add address=192.168.20.1/24 interface=vlan-iot network=192.168.20.0
add address=192.168.30.1/24 interface=vlan-guest network=192.168.30.0
add address=my.iptv.fixed.ip/9 interface=vlan2-iptv network=10.128.0.0
add address=172.17.0.1/30 interface=wg-sts-iptv-al network=172.17.0.0
add address=172.17.0.5/30 interface=wg-sts-iptv-cr network=172.17.0.4
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes
/ip cloud back-to-home-user
add allow-lan=yes name=C53UiG+5HPaxD2HPaxD public-key=\
"xxxxxxxxxxx"
/ip dhcp-client
add add-default-route=no interface=vlan3-telefono name=client1 use-peer-dns=\
no use-peer-ntp=no
/ip dhcp-server matcher
add address-pool=pool-iptv code=60 matching-type=exact name=descos server=\
dhcp-home value="[IAL]"
add address=192.168.10.0/24 comment=vlan-home dns-server=\
45.90.28.20,45.90.30.20,192.168.10.1 gateway=192.168.10.1
add address=192.168.10.240/28 comment=iptv-network dhcp-option=opch-imagenio \
dns-server=172.23.101.98 gateway=192.168.10.1 netmask=24
add address=192.168.20.0/24 comment=vlan-iot dns-server=\
45.90.28.20,45.90.30.20,192.168.20.1 gateway=192.168.20.1
add address=192.168.30.0/24 comment=vlan-guest dns-server=\
45.90.28.20,45.90.30.20,192.168.30.1 gateway=192.168.30.1 netmask=32
set mdns-repeat-ifaces=vlan-home,vlan-iot,vlan-guest servers=1.1.1.1,1.0.0.1 \
verify-doh-cert=yes
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 \
in-interface=lo src-address=127.0.0.1
add action=accept chain=input comment="vlans: accept voip and iptv vlans" \
in-interface-list=VLANs2&3
add action=accept chain=input comment="iptv: allow gre for eoip-al" \
in-interface=wg-sts-iptv-al protocol=gre
add action=accept chain=input comment="iptv: allow gre for eoip-cr" \
in-interface=wg-sts-iptv-cr protocol=gre
add action=accept chain=input comment="vpn: allow wireguard gorron-al" \
dst-port=54321 protocol=udp
add action=accept chain=input comment="vpn: allow wireguard gorron-cr" \
dst-port=54322 protocol=udp
add action=accept chain=input comment="VLANs can use router DNS" disabled=yes \
dst-port=53 in-interface-list=VLANS protocol=udp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
in-interface-list=WAN
add action=masquerade chain=srcnat comment="VLANs2&3: masquerade" \
out-interface-list=VLANs2&3
/ip firewall service-port
set rtsp disabled=no
/ip ssh
set host-key-type=ed25519 strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=vlan2-iptv upstream=yes
/routing rip interface-template
add instance=rip interfaces=vlan2-iptv,vlan3-telefono mode=passive
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name="hAP ax^3"
/system ntp client
set enabled=yes
/system ntp client servers
add address=hora.roa.es
add address=minuto.roa.es
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
/tool sniffer
set filter-interface=ether2
Thanks in advance!
