I have a script to get all address list with number of dynamic and static entries like this: (comments added to be able to understand it )
# Sett arryays to empty string to declare them
# This holds unique name of lists
:local array [ :toarray "" ]
# Used to count dynamic address list
:local addrcntdyn [:toarray ""]
# Used to count static address list
:local addrcntstat [:toarray ""]
# Loop trough all address inn address-lists
:foreach id in=[/ip firewall address-list find] do={
# Get the entry
:local rec [/ip firewall address-list get $id]
# Get name of list
:local listname ($rec->"list")
# Get if its dynamic or not
:local listdynamic ($rec->"dynamic")
# Store evry enuque liat name to "array"
:set ( $array->$listname ) 1
# Test if its dynamic or static
if ($listdynamic = true) do={
# If dynamic increment k,v pair by 1
:set ($addrcntdyn->$listname) ($addrcntdyn->$listname+1)
} else={
# If static increment k,v pair by 1
:set ($addrcntstat->$listname) ($addrcntstat->$listname+1)}
# Run troug all lists found in "array"
:foreach k,v in=$array do={
# log list name and number of dynamic and static entry
# :log info message=("script=address_lists list=$k dynamic=".(($addrcntdyn->$k)+0)." static=".(($addrcntstat->$k)+0))
# Just for test, print instead of log
:put ("script=address_lists list=$k dynamic=".(($addrcntdyn->$k)+0)." static=".(($addrcntstat->$k)+0))
Typical output: (This is what I get and its how I would like the output to be)
script=address_lists list=Blocked dynamic=1 static=7
script=address_lists list=Clients dynamic=0 static=2
script=address_lists list=FW_Block_user_try_unkown_port dynamic=1079 static=0
script=address_lists list=IPSEC dynamic=1 static=0
script=address_lists list=Router dynamic=0 static=1
script=address_lists list=Whitelist_IP dynamic=3 static=2
script=address_lists list=black_list_ftp dynamic=1 static=0
script=address_lists list=black_list_rdp dynamic=41 static=0
script=address_lists list=rdp_stage1 dynamic=28 static=0
script=address_lists list=rdp_stage2 dynamic=24 static=0
You can just cut and past this script to your system for test,
But can it be made simpler? faster?
