jan/17/2015 11:38:36 by RouterOS 6.10
software id = J0HH-NR4D
add l2mtu=1598 name=bridge1 protocol-mode=none
/ip hotspot profile
set [ find default=yes ] login-by=http-chap,https,http-pap
add hotspot-address=10.10.5.1 login-by=https,http-pap name=hsprof1
use-radius=yes
/ip hotspot
add disabled=no idle-timeout=55m interface=bridge1 name=hotspot1 profile=
hsprof1
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d name=default-fast rate-limit=3000k/2500k
add idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d name=fast
rate-limit=1000k/1000k transparent-proxy=yes
add idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d name=medium
rate-limit=1000k/600k transparent-proxy=yes
add idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d name=slow
rate-limit=1000k/300k transparent-proxy=yes
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=hs-pool-14 ranges=10.10.5.15-10.10.10.254
add address-pool=hs-pool-14 disabled=no interface=bridge1 lease-time=1h name=
dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/queue simple
add name=Total target=ether1
add disabled=yes max-limit=512k/512k name=tammy target=10.10.5.238/32
/snmp community
set [ find default=yes ] name=interisp
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add name=webproxylog remote=10.10.5.235 target=remote
/tool user-manager customer
set admin password=xxxxx
/tool user-manager profile
add name=“Default” name-for-users=“” override-shared-users=1 owner=admin
price=0 starts-at=logon validity=0s
add name=1Mbps name-for-users=“Default 2” override-shared-users=off owner=
admin price=0 starts-at=logon validity=4w
/user group
set read policy=“local,reboot,read,test,winbox,password,sniff,sensitive,api,!t
elnet,!ssh,!ftp,!write,!policy,!web”
set write policy=“local,reboot,read,write,test,winbox,password,sensitive,!teln
et,!ssh,!ftp,!policy,!web,!sniff,!api”
add name=sniffer
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
/interface bridge settings
set use-ip-firewall-for-pppoe=yes use-ip-firewall-for-vlan=yes
/ip accounting
set enabled=yes threshold=2560
/ip accounting web-access
set accessible-via-web=yes address=10.10.5.163/32
add address=10.10.5.1/24 comment=“hotspot network” interface=bridge1
network=10.10.5.0
add address=185.34.16.117/28 interface=ether1 network=xx.xx.xx.xx
add address=10.10.5.0/24 comment=“hotspot network” dns-server=
xx.xx.xx.xx,8.8.8.8 gateway=10.10.5.1
set servers=xx.xx.xx.,4.2.2.2,8.8.8.8,4.2.2.4
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
add action=reject chain=forward content=facebook disabled=yes reject-with=
icmp-admin-prohibited src-address-list=“”
add action=reject chain=forward content=youtube disabled=yes reject-with=
add action=drop chain=forward disabled=yes layer7-protocol=“(unknown)”
“place hotspot rules here” disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
src-address=10.5.70.0/24 to-addresses=0.0.0.0
src-address=10.10.5.0/24 to-addresses=0.0.0.0
add action=dst-nat chain=dstnat disabled=yes dst-address=95.170.205.199
dst-port=2000 protocol=tcp to-addresses=10.10.5.2 to-ports=8291
add action=dst-nat chain=dstnat dst-address=180.25.11.125 dst-port=5000
protocol=tcp to-addresses=10.10.5.5 to-ports=8291
/ip hotspot ip-binding
add comment=john mac-address=xx:xx:xx:xx:xx:xx type=bypassed
************************************* 200 users************
add comment=“bryan adam” name=bryan password=82
profile=Default 2
/ip proxy
set cache-administrator=revert enabled=yes max-cache-size=none parent-proxy=
0.0.0.0 src-address=0.0.0.0
add distance=1 gateway=xx.xx.xx.xx
/ip service
set ssh disabled=yes
set api disabled=yes
/ip upnp
set allow-disable-external-interface=no
/radius
add address=127.0.0.1 secret=12345 service=hotspot
/radius incoming
set accept=yes
/snmp
set enabled=yes trap-community=interisp
/system clock
set time-zone-name=xxxxx
/system identity
set name=“Main Server”
/system logging
add action=webproxylog prefix=proxy topics=web-proxy
/system ntp client
set enabled=yes primary-ntp=207.46.197.32 secondary-ntp=4.2.2.2
/system scheduler
add interval=1m name=schedule1 on-event=RC policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api
start-date=jun/08/1970 start-time=10:24:50
add comment=“starting night user” interval=1d name=start-night on-event=
enableNight_rule policy=
start-date=nov/27/2014 start-time=09:30:00
add comment=“starting night user” interval=1d name=stop-night on-event=
disableNight_rule policy=
start-date=nov/27/2014 start-time=10:00:00
/system script
add name=enableBia2_rule policy=
source=“/ip proxy access enable [find comment="bia2"]”
add name=disableBia2_rule policy=
source=“/ip proxy access disable [find comment="bia2"]”
add name=enableNight_rule policy=
source=“/ip hotspot user enable [find user="night"]”
add name=disableNight_rule policy=
source=“/ip hotspot user disable [find user="night"]”
add name=removeActiveNight policy=
source=“/ip hotspot active find user="night"”
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=127.0.0.1 log=
auth-ok,auth-fail,acct-ok,acct-fail name=“Main server” shared-secret=
12345 use-coa=no
/tool user-manager user
add caller-id=CC:3A:61:70:E2:80 comment=“it manager” customer=admin disabled=
no email=t@gmail.com first-name=rever last-name=makort location=
name=re password=xxxx phone=xxxxxx shared-users=1
wireless-enc-algo=none wireless-enc-key=“” wireless-psk=“”
