I have looked all over the place, and followed all sorts of instructions, and none of them are helping me figure out my problem.
I initially had my router working how I am trying to get it working again, but I stopped using the other IP addresses, so I removed them from the configuration, and assigned all the ports to a bridge connected to the LAN, thinking that I knew how to set them up again if I need to in the future. I didn’t realize that the future was going to be 5 years down the road, and I would forget everything.
I have a /29 block of IP addresses, xxx,yyy.zzz.200/29. I have things setup so that I have two LANs that use xxx.yyy.zzz.202 for their public IP. I assigned each LAN a private subnet, which are 10.0.1.0/24, and 10.1.0.0/24, although that shouldn’t matter. I need to assign one of my other public IP addresses to a server that I have on port eth3. I have removed eth3 from the bridge, and that is the only part I am sure I got correct.
Anyway, I was hoping someone could help me figure out what I need to do to get this working.
