Hello all,
This is my first post so please be gentle.
I’m installing a Mikrotik RB2011L-RM at a data center, and I had it set up to use static IP’s except at the last minute this specification has changed to a routed subnet! As I have one day to figure this out I thought I would ask for help here.
I attached an image of the topology we will be using for clarity, but I need help with the configuration. In a nutshell;
- The WAN connection of the router has been given a 78.x.x.18 on a /30 subnet, with .17 being the ISP’s gateway.
- We have been provided a routed subnet of 79.x.x.24/29 to use for our own use.
- Five of the IP’s need to be 1:1 NAT’d (or destination/source NAT’d if you prefer) to the private LAN addresses in the image.
- One of the IP’s is to be passed through and used on an offsite router for a client. I assume I just set up the WAN interface of their router with the static IP.
- Due to the nature of the existing setup (before I move to the above setup) the private IP’s (10.19.14.x) need to be in place. We can’t assign the public IP’s directly on the VM’s and host.
I appreciate any help that can be given.
Thank you for reading.
Chris
