help usb 3g modem & PCC
hi all
can i make pcc from multi usb 3g modems ?
thx
Same as in example, only instead of gateway IPs you should use gateway interfaces.
http://wiki.mikrotik.com/wiki/Manual:PCC
1st of all thank you for your post
infact if you give me direct roll its a great idea
i have tow usb 3g modem
ppp-out1 port usb3 in system → resourses → usb 1:2 huawai
ppp-out2 port usb4 in system → resourses → usb 1:3 huawai
ether1 10.5.50.1/24 10.5.50.0 10.5.50.255
thanks
