Hi all,
which is the main difference between using policy routing rule instead using mangle to route traffic to a second isp?
I have a CCR1016 and ROS 6.46.8.
What i’m tring to do is to routing a subnet trought a second gateway ISP.
My problem is that if i use mangle and routing marks it won’t works.
this is not working conf:
dec/31/2020 11:48:33 by RouterOS 6.46.8
software id = E400-S2IH
model = CCR1016-12G
serial number = D5440C7FBF61
add name=Lan
add name=bridge_Privato
add name=bridge_Pubblico
set [ find default-name=ether1 ] name=ether1-Swisscom
set [ find default-name=ether2 ] name=ether2-Cablecom
set [ find default-name=ether3 ] name=ether3-WIFI
set [ find default-name=ether4 ] name=ether4-Lan
set [ find default-name=ether8 ] name=ether8-HA
/interface vlan
add interface=ether3-WIFI name=vlan_Privato vlan-id=41
add interface=ether3-WIFI name=vlan_Pubblico vlan-id=42
add interface=ether1-Swisscom name=vlan_swisscom vlan-id=12
add name=LAN
add name=WAN
add name=pool_Lan ranges=192.168.1.120-192.168.1.220
add name=pool_privato ranges=10.0.41.100-10.0.41.200
add name=pool_Pubblico ranges=10.0.42.100-10.0.42.200
add name=Pool_VPN_FPSRocco ranges=10.155.0.100-10.155.0.250
add address-pool=pool_Lan disabled=no interface=Lan lease-time=1h name=
server_lan
add address-pool=pool_privato disabled=no interface=bridge_Privato name=
server_Privato
add address-pool=pool_Pubblico disabled=no interface=bridge_Pubblico name=
server_Pubblico
add bridge=Lan interface=ether3-WIFI
add bridge=Lan interface=ether4-Lan
add bridge=bridge_Privato interface=vlan_Privato
add bridge=bridge_Pubblico interface=vlan_Pubblico
add bridge=Lan interface=ether10
add bridge=Lan interface=ether8-HA
set enabled=yes
/ip settings
set allow-fast-path=no rp-filter=strict tcp-syncookies=yes
add interface=Lan list=LAN
add interface=bridge_Privato list=LAN
add interface=vlan_swisscom list=WAN
add interface=bridge_Pubblico list=LAN
add interface=ether2-Cablecom list=WAN
add interface=ether1-Swisscom list=WAN
add address=192.168.1.1/24 comment=defconf interface=Lan network=192.168.1.0
add address=192.168.8.2/24 interface=vlan_swisscom network=192.168.8.0
add address=10.0.41.1/24 comment=defconf interface=bridge_Privato network=
10.0.41.0
add address=10.0.42.1/24 comment=defconf interface=bridge_Pubblico network=
10.0.42.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no disabled=no interface=ether2-Cablecom use-peer-dns=
no
/ip dhcp-server lease
add address=192.168.1.253 client-id=1:48:8f:5a:f1:33:87 mac-address=
48:8F:5A:F1:33:87 server=server_lan
add address=10.0.41.0/24 dns-server=10.0.41.1 domain=sanrocco.local gateway=
10.0.41.1
add address=10.0.42.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.0.42.1
add address=192.168.1.0/24 dns-server=192.168.1.112,192.168.1.114 domain=
sanrocco.local gateway=192.168.1.1
set allow-remote-requests=yes servers=192.168.1.112,192.168.1.114
/ip firewall address-list
add address=46.88.77.96/27 list=Allowed
add address=76.55.208.25 list=Allowed
add address=192.168.1.0/24 list=DDosExeption
add address=192.168.1.112 list=DDosExeption
add address=192.168.1.114 list=DDosExeption
add address=192.168.1.0/24 list=private_ipv4
add address=10.0.41.0/24 list=private_ipv4
add address=192.168.1.112 list=DNSServer
add address=192.168.1.114 list=DNSServer
add address=10.0.42.0/24 list=private_ipv4
add address=10.0.42.0/24 list=ToCablecom
add address=10.0.41.0/24 list=ToSwisscom
add address=192.168.1.0/24 list=ToSwisscom
add address=192.168.8.0/24 list=Connected
add address=192.168.0.0/24 list=Connected
add action=accept chain=input comment=“–0-1-- Allowed IP” src-address-list=
Allowed
add action=accept chain=forward comment=“–0-2-- Allowed IP”
src-address-list=Allowed
add action=accept chain=input comment=“Allow OpenVPN” dst-port=1194
in-interface-list=WAN protocol=tcp
add action=drop chain=forward comment=“Isolate Pubblic Network”
connection-state=new dst-address=192.168.1.0/24 src-address=10.0.42.0/24
add action=accept chain=output comment=“–10-0-- Firewall Rule” disabled=yes
“–10-1-- defconf: accept established,related,untracked”
add action=drop chain=input comment=“–10-2-- defconf: drop invalid”
connection-state=invalid
“–10-3-- defconf: drop all not coming from LAN” in-interface-list=!LAN
src-address=!10.155.0.0/24
“–10-4-- defconf: accept in ipsec policy” ipsec-policy=in,ipsec
“–10-5-- defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=
“–10-6-- defconf: fasttrack” connection-state=established,related
disabled=yes
“–10-7-- defconf: accept established,related, untracked”
add action=drop chain=forward comment=“–10-8-- defconf: drop invalid”
“–10-9-- defconf: drop all from WAN not DSTNATed” connection-nat-state=
!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=
!private_ipv4 new-routing-mark=ToCablecom
src-address-list=ToCablecom
!private_ipv4 new-routing-mark=ToSwisscom
src-address-list=ToSwisscom
add action=masquerade chain=srcnat dst-address-list=!private_ipv4
ipsec-policy=out,none out-interface-list=WAN src-address=192.168.1.0/24
ipsec-policy=out,none out-interface-list=WAN src-address=10.0.41.0/24
ipsec-policy=out,none out-interface-list=WAN src-address=10.0.42.0/24
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=
WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=ToCablecom
add check-gateway=ping distance=1 gateway=192.168.8.1 routing-mark=ToSwisscom
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
But adding a “policy routing rule” in the /ip route and removing the mangle mark it works
This is the working config:
model = CCR1016-12G
add name=Lan
/interface vlan
add name=LAN
add name=WAN
server_lan
server_Privato
server_Pubblico
set enabled=yes
/ip settings
10.0.41.0
10.0.42.0
/ip cloud
/ip dhcp-client
no
10.0.41.1
Allowed
disabled=yes
WAN
add check-gateway=ping distance=2 gateway=192.168.0.1
/ip route rule
add action=lookup-only-in-table interface=bridge_Pubblico table=ToCablecom
/ip service
I can’t understand why…
