[help] WDS + WPA2-EAP + FreeRadius = failure
Hello
I’m trying to do WDS WPA2-EAP TLS authentication of 2 RB600
Simple WDS AP+station without EAP is working.
I’ve already searched forum for related topics. but they didn’t help me.
So what do i have:
2x RB600
CentOS 5.5
=> freeradius2-2.1.7-7.el5 + mysql Ver 14.12 Distrib 5.0.77, + daloRADIUS 0.9.8 (SVN 0.9.9)
This setup works perfectly with Ubiquiti Nanobridge M5 EAP-TTLS.
What i’ve done on RB’s:
Wireless interface: WDS static, AP bridge + station on other RB. SSID,FQ,Band = same
Time and date adjusted for proper cert authentication.
Most things i’m doing through winbox gui.
AP bridge security profile and rad. server:
[admin@RB600_test1] > /radius print
Flags: X - disabled
 #   SERVICE          CALLED-ID       DOMAIN       ADDRESS         SECRET
 0   wireless                                      192.168.0.29    secret
AP Security profile:
So how should i configure WDS station ??? here what i have on it:
Here’s debug of radius:
It’s says that it can’t identify username. what should i write in db as username? as i knew EAP-TLS is using certificate authentication without usernames and passwords like EAP-TTLS is doing.
Also i’ve attached full freeradius debug with initial radius boot log, loaded modules and rad configurations.
Ready to process requests.
rad_recv: Access-Request packet from host 192.168.0.22 port 41953, id=93, length=201
	Service-Type = Framed-User
	Framed-MTU = 1400
	Acct-Session-Id = "82100859"
	Acct-Multi-Session-Id = "00-0C-42-31-5C-70-00-0C-42-23-48-0A-82-10-00-00-00-00-08-59"
	Calling-Station-Id = "00-0C-42-23-48-0A"
	Called-Station-Id = "00-0C-42-31-5C-70:MikroTik-test"
	EAP-Message = 0x0200000501
	Message-Authenticator = 0x99441f609c780c7b28d234de47b36283
	NAS-Identifier = "RB600_test1"
	NAS-IP-Address = 192.168.0.22
+- entering group authorize {...}
++[preprocess] returns ok
++[chap] returns noop
++[mschap] returns noop
[suffix] Proxy reply, or no User-Name.  Ignoring.
++[suffix] returns ok
[eap] EAP packet type response id 0 length 5
[eap] No EAP Start, assuming it's an on-going EAP conversation
++[eap] returns updated
++[unix] returns noop
++[files] returns noop
[sql] 	expand: %{User-Name} ->
[sql] sql_set_user escaped user --> ''
rlm_sql (sql): Reserving sql socket id: 3
[sql] 	expand: SELECT id, username, attribute, value, op           FROM radcheck           WHERE username = '%{SQL-User-Name}'           ORDER BY id -> SELECT id, username, attribute, value, op           FROM radcheck           WHERE username = ''           ORDER BY id
[sql] 	expand: SELECT groupname           FROM radusergroup           WHERE username = '%{SQL-User-Name}'           ORDER BY priority -> SELECT groupname           FROM radusergroup           WHERE username = ''           ORDER BY priority
rlm_sql (sql): Released sql socket id: 3
[sql] User  not found
++[sql] returns notfound
++[expiration] returns noop
++[logintime] returns noop
[pap] WARNING! No "known good" password found for the user.  Authentication may fail because of this.
++[pap] returns noop
[b]Found Auth-Type = EAP
+- entering group authenticate {...}
[eap] UserIdentity Unknown
[eap] Identity Unknown, authentication failed
[eap] Failed in handler
++[eap] returns invalid
Failed to authenticate the user.
Login incorrect: [<no User-Name attribute>] (from client RB600_test1 port 0 cli 00-0C-42-23-48-0A)
Using Post-Auth-Type Reject
+- entering group REJECT {...}
[attr_filter.access_reject] 	expand: %{User-Name} ->
++[attr_filter.access_reject] returns noop
Delaying reject of request 0 for 1 seconds[/b]
Going to the next request
Waking up in 0.9 seconds.
Waiting to send Access-Reject to client RB600_test1 port 41953 - ID: 93
Waking up in 0.5 seconds.
Sending delayed reject for request 0
Sending Access-Reject of id 93 to 192.168.0.22 port 41953
Waking up in 4.9 seconds.
Cleaning up request 0 ID 93 with timestamp +35
rad_recv: Access-Request packet from host 192.168.0.22 port 54462, id=94, length=201
	Framed-MTU = 1400
	Acct-Session-Id = "8210085a"
	Acct-Multi-Session-Id = "00-0C-42-31-5C-70-00-0C-42-23-48-0A-82-10-00-00-00-00-08-5A"
	Message-Authenticator = 0xed7b325c353b295032cd7532f1b225cb
rlm_sql (sql): Reserving sql socket id: 2
rlm_sql (sql): Released sql socket id: 2
Delaying reject of request 1 for 1 seconds
Waiting to send Access-Reject to client RB600_test1 port 54462 - ID: 94
Waking up in 0.4 seconds.
Sending delayed reject for request 1
Sending Access-Reject of id 94 to 192.168.0.22 port 54462
Sending duplicate reply to client RB600_test1 port 54462 - ID: 94
Cleaning up request 1 ID 94 with timestamp +73
error:
± entering group authenticate {…}
Login incorrect: [] (from client RB600_test1 port 0 cli 00-0C-42-23-48-0A)
± entering group REJECT {…}
[attr_filter.access_reject] expand: %{User-Name} →
FULLdebug_withradboot_log.txt (26.2 KB)
Mikrotik don’t support eap ttls or peap as client! you can use eap tls with certificate on both sides.
I tested ttls and peap with nanobridges an rocket, do not work really well, when the station is reset the link is established but not working…
man read carefully first strings of my message :slight_smile:
Hello
I’m trying to do WDS > WPA2-EAP TLS > authentication of 2 RB600
i told about ttls to notify that generally my radius-sql-daloradius is working. and TTLS radius module depends on pre-configured TLS module.
from debug i can see that radius can’t obtain useridentity from client.
than i’ve found some kind of “solution” with two variants and uncommented next strings in eap.conf (first time, the first time. and the second time commented first and uncommented second one)
check_cert_issuer = "/C=ZZ/ST=Yyyyy/L=yyyyy/O=Xxx"
or
check_cert_cn = %{User-Name}
But it didn’t worked
maybe someone can help me with proper configuration ??? radius can’t get user identity… what is proper config for eap.conor mikrotik side configuration for AP and station ?
